Salta al contenuto principale
Sony NEX-5R Rear Case Replacement
Cosa ti serve
  1. Sony NEX-5R Rear Case Replacement, Front Case: passo 1, immagine 1 di 2 Sony NEX-5R Rear Case Replacement, Front Case: passo 1, immagine 2 di 2
    • Open the battery pack door by moving the slider to "OPEN".
    • Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
  2. Sony NEX-5R Rear Case Replacement: passo 2, immagine 1 di 1
    • Remove the 3.25 mm exterior screw with a Phillips screwdriver.
  3. Sony NEX-5R Rear Case Replacement: passo 3, immagine 1 di 2 Sony NEX-5R Rear Case Replacement: passo 3, immagine 2 di 2
    • Use the spudger to raise the corner of the case from the camera.
    • One component of the front case should now be separate from the camera.
  4. Sony NEX-5R Rear Case Replacement, Rear Case: passo 4, immagine 1 di 1
    • Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
  5. Sony NEX-5R Rear Case Replacement: passo 5, immagine 1 di 1
    • Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
  6. Sony NEX-5R Rear Case Replacement: passo 6, immagine 1 di 1
    • Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
  7. Sony NEX-5R Rear Case Replacement: passo 7, immagine 1 di 1
    • Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
  8. Sony NEX-5R Rear Case Replacement: passo 8, immagine 1 di 2 Sony NEX-5R Rear Case Replacement: passo 8, immagine 2 di 2
    • Using the spudger again, carefully pry from the top of the camera to remove the back frame.
    • The back frame is fragile, so use the spudger gently.
  9. Sony NEX-5R Rear Case Replacement: passo 9, immagine 1 di 1
    • The back case should now be removed and look like this.
Conclusione
Emily Trujillo
Membro da: 04/08/14
1.114 Reputazione
6 Guide realizzate
Cal Poly, Team 8-9, Regan Spring 2014 Membro di Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 24
Tutti i Tempi: 2,592
