Salta al contenuto principale
Sony NEX-5R Lens Mount Replacement
Cosa ti serve
  1. Sony NEX-5R Lens Mount Replacement, Lens Mount: passo 1, immagine 1 di 2 Sony NEX-5R Lens Mount Replacement, Lens Mount: passo 1, immagine 2 di 2
    • Hold lens and camera securely with two hands.
    • With the hand holding the camera, push down on the lens button. Twist the lens counterclockwise and pull out to release lens.
  2. Sony NEX-5R Lens Mount Replacement: passo 2, immagine 1 di 1
    • Using your screwdriver, remove the four (3.5 mm) Phillips screws on the front face of the lens mount.
    • Make sure to keep track of these screws and not misplace them.
  3. Sony NEX-5R Lens Mount Replacement: passo 3, immagine 1 di 1
    • Remove the silver plate by gently pinching with your fingers.
  4. Sony NEX-5R Lens Mount Replacement: passo 4, immagine 1 di 1
    • Now the black plate should be exposed. You can remove this again by gently pinching with your fingers and lifting up.
  5. Sony NEX-5R Lens Mount Replacement: passo 5, immagine 1 di 1
    • Using the tweezers, grab the thin silver ring and lift up.
  6. Sony NEX-5R Lens Mount Replacement: passo 6, immagine 1 di 1
    • The camera mount should now be barren and look like this.
Conclusione
Emily Trujillo
Membro da: 04/08/14
1.114 Reputazione
6 Guide realizzate
Cal Poly, Team 8-9, Regan Spring 2014 Membro di Cal Poly, Team 8-9, Regan Spring 2014
CPSU-REGAN-S14S8G9
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,514
