Salta al contenuto principale
Sony MVC-FD200 Back Cover Replacement
Cosa ti serve
  1. Sony MVC-FD200 Back Cover Replacement, Battery: passo 1, immagine 1 di 1
    • Using your finger, slide the tab on the battery door up to release the battery latch.
  2. Sony MVC-FD200 Back Cover Replacement: passo 2, immagine 1 di 1
    • Lift the battery door to reveal the battery compartment.
    • Push the gray lever to the left side to remove the battery.
    • If any other repairs are needed, make sure to carefully remove the battery to avoid any electric shock or short circuits during repairs.
  3. Sony MVC-FD200 Back Cover Replacement, Back Cover: passo 3, immagine 1 di 1
    • Turn the camera so that the top is facing down towards the table.
    • Using the Phillips #00 screwdriver, remove all 2.0 mm screws with the arrows facing towards them.
  4. Sony MVC-FD200 Back Cover Replacement: passo 4, immagine 1 di 2 Sony MVC-FD200 Back Cover Replacement: passo 4, immagine 2 di 2
    • Flip the camera on both sides and remove the rest of the screws with arrows facing towards them.
    • Remove the 2.0 mm screws with the Phillips #00 screwdriver for both sides of the camera.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 99
