Salta al contenuto principale
Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement
Cosa ti serve
  1. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement, Swivel: passo 1, immagine 1 di 1
    • Begin by laying the headphones down flat with the speakers facing up.
    • Be sure to unplug the headphones from any other devices.
  2. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: passo 2, immagine 1 di 2 Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: passo 2, immagine 2 di 2
    • Next, take out the screws that hold the front plate, using a J00 screwdriver.
    • Repeat for both the left and right screws.
    • These screws are very small. It is helpful to have a spot prepared to put the screws to avoid losing pieces.
  3. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: passo 3, immagine 1 di 1
    • Now that the screws have been removed, pull away the plastic casing that covers the swivel piece (directly above the speaker).
  4. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: passo 4, immagine 1 di 1
    • Now that the swivel piece is exposed, use a J00 screwdriver to unscrew the center screw.
    • Repeat this process on both sides if necessary.
    • This center screw is the piece that retains the swivel action, unscrew completely and remove to replace.
  5. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement, Swivel Plastic Cover: passo 5, immagine 1 di 1
    • With the swivel screw removed, remove the plastic casing.
  6. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: passo 6, immagine 1 di 1
    • Using a little amount of force, slide the plastic cover off of the headband.
  7. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: passo 7, immagine 1 di 1
    • Pull the plastic until the cover is fully removed.
Conclusione
Un commento
Necesito la pieza, dónde la compro?
lucas2188 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 3,236
