Salta al contenuto principale
Sony MDR-XB450AP Extra Bass Headphones Cushion Replacement
Cosa ti serve
  1. Sony MDR-XB450AP Extra Bass Headphones Cushion Replacement, Cushion: passo 1, immagine 1 di 1
    • Begin by laying the headphones down flat on a surface.
    • Make sure that the headphone speakers are facing upward.
    • Be sure to check that the headphones are not plugged into any devices.
  2. Sony MDR-XB450AP Extra Bass Headphones Cushion Replacement: passo 2, immagine 1 di 1
    • Using the plastic opening tools, gently pry the speaker from the headphone's base.
    • There will be some tearing involved, but this is necessary to remove the original cushion.
    • The cushion is bonded to the headphones with a circular adhesive strip. If you plan on reusing the cushion, try to keep the adhesive attached to the cushion during removal. This way the cushion can be easily re-attached to the headphones after repair.
Conclusione
Altre 8 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 4,533
