Introduzione
The mechanism deck is responsible for turning the tape at the correct speed so that your recordings record and playback properly. This guide shows you how to replace the mechanism deck and get your microcassette-corder back in working order.
Cosa ti serve
Using a spudger, apply pressure towards the back corner of the cassette compartment to the plastic tab directly behind the gold cone.
Pushing the tab allows the hinge to be separated from the body of the device.
Find the arrow on the battery cover on the back of the device.
While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
Next, twist it to the side as shown in the second picture. The lid should simply snap off.
Use a spudger to push in the two tabs located on the bottom of the device.
It works best to push the tabs at an upward angle (towards the top of the battery compartment)
It may take a decent amount of force in order to push in the tabs.
I didn’t push on the tabs, but put a spudger along the seem and the clips released with minimal force!
Using tweezers, pull upward on the black tape which secures the wires.
Removing this tape allows you to move the wires out of the way for the next step.
If the replacement motherboard does not have the wire battery terminals attached, desolder the two battery connections on the motherboard.
Leave the wire battery terminals in place.
If the replacement motherboard has battery terminals attached, the connections do not need to be desoldered.
First, remove the buttons from the mechanism deck so that you can remove it from the case.
Find the tabs on each button.
Push the tab with a spudger away from the metal connection.
Pull button away from the mechanism deck to remove it.
Remove the mechanism deck by lifting the tab as shown.
What type of drive belt is that? How long is it? I can't seem to find the information online anywhere
Altre 7 persone hanno completato questa guida.
3 Commenti
I would greatly appreciate receiving some info regarding where to get parts or a full mechanism deck replacement for Sony M-607V microcassette recorder. Also if it is possible to get a Service Manual with exploded views.
Thanks in advance for any help.
Hermann
