Salta al contenuto principale
Sony ICF-C1iPMK2 Speaker Replacement
Cosa ti serve
  1. Sony ICF-C1iPMK2 Speaker Replacement, Speaker: passo 1, immagine 1 di 2 Sony ICF-C1iPMK2 Speaker Replacement, Speaker: passo 1, immagine 2 di 2
    • Unscrew the 1 cm Phillips #00 screws.
    • Use spudger to loosen the back panel of the device.
  2. Sony ICF-C1iPMK2 Speaker Replacement: passo 2, immagine 1 di 3 Sony ICF-C1iPMK2 Speaker Replacement: passo 2, immagine 2 di 3 Sony ICF-C1iPMK2 Speaker Replacement: passo 2, immagine 3 di 3
    • This step contains ribbon cables. Be careful to not bend or rip these fragile cables, to protect your device.
    • Slowly pull the back panel off until it separated from the main panel.
    • Carefully unplug all of the ribbon cables connecting the back panel to the main panel.
  3. Sony ICF-C1iPMK2 Speaker Replacement: passo 3, immagine 1 di 3 Sony ICF-C1iPMK2 Speaker Replacement: passo 3, immagine 2 di 3 Sony ICF-C1iPMK2 Speaker Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the power connector with a pair of ESD safe tweezers.
    • Remove the Aux port connector with a pair of ESD safe tweezers.
    • Slide the button panels out of the chassis.
  4. Sony ICF-C1iPMK2 Speaker Replacement: passo 4, immagine 1 di 3 Sony ICF-C1iPMK2 Speaker Replacement: passo 4, immagine 2 di 3 Sony ICF-C1iPMK2 Speaker Replacement: passo 4, immagine 3 di 3
    • Unscrew the four 1 cm Phillips #00 screws and remove the speaker cover.
    • Unscrew the 1 cm Phillips #00 screws holding the speaker in place.
    • Remove the old speaker and insert the new one.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 88
