Salta al contenuto principale
Sony ICF-C1T Tuner Dial Replacement
Cosa ti serve
  1. Sony ICF-C1T Tuner Dial Replacement, Tuner Dial: passo 1, immagine 1 di 1
    • Using the Phillips #00 screwdriver, remove four 14mm screws from the underside of the device.
    • Make sure that the clock is unplugged and the battery is removed before tampering with the device to avoid electrical shock.
  2. Sony ICF-C1T Tuner Dial Replacement: passo 2, immagine 1 di 1
    • Use the opening tool to pry apart the edges of the top and side portions of the device.
  3. Sony ICF-C1T Tuner Dial Replacement: passo 3, immagine 1 di 2 Sony ICF-C1T Tuner Dial Replacement: passo 3, immagine 2 di 2
    • Separate the device by gently pulling up on the top portion.
    • Use caution when pulling the device apart as the clock display is located close to the front face plate and is connected by multiple wires.
  4. Sony ICF-C1T Tuner Dial Replacement: passo 4, immagine 1 di 2 Sony ICF-C1T Tuner Dial Replacement: passo 4, immagine 2 di 2
    • To remove the motherboard, gently pull apart the sides of the device.
    • Do not pull hard on the motherboard, because it is still connected by multiple wires inside the device.
    • Be careful of sharp pieces on the motherboard.
    • Having help for this step might make things quicker and easier.
  5. Sony ICF-C1T Tuner Dial Replacement: passo 5, immagine 1 di 3 Sony ICF-C1T Tuner Dial Replacement: passo 5, immagine 2 di 3 Sony ICF-C1T Tuner Dial Replacement: passo 5, immagine 3 di 3
    • Remove the tuner dial by pulling it off of the motherboard. This can take a little force to remove.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,515
