Salta al contenuto principale
Sony ICF-C1T Speaker Replacement
Cosa ti serve
  1. Sony ICF-C1T Speaker Replacement, Speaker: passo 1, immagine 1 di 2 Sony ICF-C1T Speaker Replacement, Speaker: passo 1, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove the four 14mm screws from the underside of the device.
    • Be sure that the device is unplugged and the battery has been removed before tampering with the device.
  2. Sony ICF-C1T Speaker Replacement: passo 2, immagine 1 di 1
    • Using the opening tool, gently pry the top portion from the side section of your device.
  3. Sony ICF-C1T Speaker Replacement: passo 3, immagine 1 di 2 Sony ICF-C1T Speaker Replacement: passo 3, immagine 2 di 2
    • Gently pull the top of the clock away from the rest of the device.
    • Be careful when tugging on this piece of the clock. The clock display is located directly inside the front face and is connected by multiple wires.
  4. Sony ICF-C1T Speaker Replacement: passo 4, immagine 1 di 2 Sony ICF-C1T Speaker Replacement: passo 4, immagine 2 di 2
    • Using the Phillips #00 screwdriver, remove the two 14mm screws from the top of the motherboard.
    • Be careful to avoid the sharp pieces on the motherboard when handling the device.
  5. Sony ICF-C1T Speaker Replacement: passo 5, immagine 1 di 3 Sony ICF-C1T Speaker Replacement: passo 5, immagine 2 di 3 Sony ICF-C1T Speaker Replacement: passo 5, immagine 3 di 3
    • Remove the Phillips #00 screw from the bottom of the white and blue box.
    • Remove the Phillips #00 screw from behind the white and blue box.
    • After unscrewing the white box, gently pull it out. This will allow for more room to access the speaker.
  6. Sony ICF-C1T Speaker Replacement: passo 6, immagine 1 di 1
    • To separate the motherboard completely, you can cut the red and black wires that are attached to the speaker. This will allow you to access the speaker fully.
    • Use caution when tampering with the wires and sharp parts of the device.
  7. Sony ICF-C1T Speaker Replacement: passo 7, immagine 1 di 2 Sony ICF-C1T Speaker Replacement: passo 7, immagine 2 di 2
    • Use the plastic opening tool and the spudger to separate the speaker from the device by tracing its outline and loosening the glue.
    • Do this step gently as to not damage the device or cause harm to yourself.
    • When reassembling the device, you will need to use glue to place the new speaker back in its place.
    • It would be wise to test the device after reconnecting wires, before screwing and gluing the parts back together.
Conclusione
Un commento
can I connect aux out port to speaker?
Dong-Hwan Shin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 31
Tutti i Tempi: 2,597
