Salta al contenuto principale
Sony Handycam HDR-CX580V Recording Button Replacement
Cosa ti serve
  1. Sony Handycam HDR-CX580V Recording Button Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the slider labeled "BATT" and pull it back from the battery with your thumb.
  2. Sony Handycam HDR-CX580V Recording Button Replacement: passo 2, immagine 1 di 1
    • At this point, you should be able to remove the battery by simply lifting it from the camera.
    • The camera provided for guide-creation did not include a battery. However, the battery position should be the same.
  3. Sony Handycam HDR-CX580V Recording Button Replacement, Recording Button: passo 3, immagine 1 di 3 Sony Handycam HDR-CX580V Recording Button Replacement, Recording Button: passo 3, immagine 2 di 3 Sony Handycam HDR-CX580V Recording Button Replacement, Recording Button: passo 3, immagine 3 di 3
    • Use the Phillips #00 head to remove the following 5.5mm screws on the left-hand side.
  4. Sony Handycam HDR-CX580V Recording Button Replacement: passo 4, immagine 1 di 1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the empty battery socket.
  5. Sony Handycam HDR-CX580V Recording Button Replacement: passo 5, immagine 1 di 1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the bottom.
  6. Sony Handycam HDR-CX580V Recording Button Replacement: passo 6, immagine 1 di 1
    • Fold back the hinging panel on the top of the camera located near the lens.
    • Use the Phillips #00 head to remove the following 5.5mm screws on the top under the hinging panel.
  7. Sony Handycam HDR-CX580V Recording Button Replacement: passo 7, immagine 1 di 2 Sony Handycam HDR-CX580V Recording Button Replacement: passo 7, immagine 2 di 2
    • Slide back the cover for the DC and A/V ports on the right-hand side.
    • Use the Phillips #00 head to remove the following 5.5mm screws underneath the cover and on the right-hand side.
  8. Sony Handycam HDR-CX580V Recording Button Replacement: passo 8, immagine 1 di 1
    • Use the plastic opener tool to loosen the casing on the bottom and the right-hand side.
    • At this point, the right-hand side should simply come off, although it will still be connected with internal wiring.
    • Be delicate with the wiring still attached to the side casing until you have access to removing them later.
  9. Sony Handycam HDR-CX580V Recording Button Replacement: passo 9, immagine 1 di 3 Sony Handycam HDR-CX580V Recording Button Replacement: passo 9, immagine 2 di 3 Sony Handycam HDR-CX580V Recording Button Replacement: passo 9, immagine 3 di 3
    • Carefully remove the bottom casing with your fingers.
    • Be careful not to loose the small metal stand-mount pieces that lay underneath the casing.
  10. Sony Handycam HDR-CX580V Recording Button Replacement: passo 10, immagine 1 di 1
    • Look at the right side of the camera (the side with the recording button) while holding back the detached casing.
    • Use the Phillips #00 head to remove the following 5.5mm screws near the recording button.
  11. Sony Handycam HDR-CX580V Recording Button Replacement: passo 11, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use the curved tweezers to carefully detach the blue ribbon cable connector from the body of the camera.
    • The recording button and its blue ribbon cable connector should become detached from the body, but remain connected to the top casing.
  12. Sony Handycam HDR-CX580V Recording Button Replacement: passo 12, immagine 1 di 2 Sony Handycam HDR-CX580V Recording Button Replacement: passo 12, immagine 2 di 2
    • Pull off the top casing by lightly grabbing either side and pulling towards the back of the camera.
  13. Sony Handycam HDR-CX580V Recording Button Replacement: passo 13, immagine 1 di 1
    • Use the Phillips #00 head to remove the following 5.5mm screws on the inside of the top casing.
  14. Sony Handycam HDR-CX580V Recording Button Replacement: passo 14, immagine 1 di 1
    • Carefully remove the metal frame from the top casing.
  15. Sony Handycam HDR-CX580V Recording Button Replacement: passo 15, immagine 1 di 1
    • You are now free to remove the recording button, as well as its connection strip.
Conclusione
Derek Fritz
Membro da: 03/21/17
378 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 419
