Introduzione
This guide will help to locate and remove the motherboard for replacement. This will involve removing a significant portion of the camera and wiring.
Cosa ti serve
Locate the slider labeled "BATT" and pull it back from the battery with your thumb.
Use the Phillips #00 head to remove the following 5.5mm screws on the left-hand side.
Use the Phillips #00 head to remove the following 5.5mm screws on the right-hand side near the lens.
To begin removing the metal casing, use the Phillips #00 head to remove the following 5.5mm screws.
Hold the camera so you can see the motherboard on its bottom.
With a pair of straight tweezers, carefully remove the hanging panel by the following bundled cable connectors and ribbon cable connector attached to the motherboard.
