Salta al contenuto principale
Sony Handycam HDR-CX580V Battery Replacement
  1. Sony Handycam HDR-CX580V Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the slider labeled "BATT" and pull it back from the battery with your thumb.
  2. Sony Handycam HDR-CX580V Battery Replacement: passo 2, immagine 1 di 1
    • At this point, you should be able to remove the battery by simply lifting it from the camera.
    • The camera provided for guide-creation did not include a battery. However, the battery position should be the same.
Conclusione
To replace a new battery, simply snap the battery into the slot from which you removed it from.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 22
Tutti i Tempi: 633
