Introduzione
Replacing the lens assembly requires removing sensitive electrical ribbons. Be sure to exercise extreme caution while removing this part to avoid damaging your device.
Cosa ti serve
Rotate your camera such that the underside is facing you and the lens is facing the ground.
Orient the camera such that the lens is facing to your left.
Using your right hand to hold the camera, gently remove the lens panel from the camera with your left hand.
Rotate the camera so that it is upright and the lens is pointed to your left.
Using your right hand to hold the screwdriver and your left to hold the camera, remove the single 5.5 mm Phillips #00 screw from on the top of the shutter assembly.
With the right side of the camera facing toward you, remove the single 5.5 mm Phillips #00 screw.
Altre 2 persone hanno completato questa guida.
