Salta al contenuto principale
Sony Handycam HDR-CX380 Battery Replacement
  1. Sony Handycam HDR-CX380 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Rotate your camera such that the underside is facing you and the lens is facing the ground.
    • You should be able to see the camera's label, and it should be rotated 90 degrees counterclockwise.
  2. Sony Handycam HDR-CX380 Battery Replacement: passo 2, immagine 1 di 1
    • Using your left thumb, push down the slider to the left of the SD card slot.
    • When inserting a new battery or reinserting the one you removed, you can ignore this step.
  3. Sony Handycam HDR-CX380 Battery Replacement: passo 3, immagine 1 di 2 Sony Handycam HDR-CX380 Battery Replacement: passo 3, immagine 2 di 2
    • Using your right index finger and thumb, pull the battery toward you and then away from the camera.
Conclusione
To insert a new battery or reinsert the one you removed, simply follow step 3 in reverse order and rotate the camera as described in step 1.
USF Tampa, Team 16-5, Blackwell Winter 2016 Membro di USF Tampa, Team 16-5, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G5
3 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 582
