Salta al contenuto principale
Sony Handycam HDR­-CX220 Display Screen Replacement
Cosa ti serve
  1. Sony Handycam HDR­-CX220 Display Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Display Screen Replacement: passo 2, immagine 1 di 1
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: passo 3, immagine 1 di 3 Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: passo 3, immagine 2 di 3 Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: passo 3, immagine 3 di 3
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Display Screen Replacement: passo 4, immagine 1 di 3 Sony Handycam HDR­-CX220 Display Screen Replacement: passo 4, immagine 2 di 3 Sony Handycam HDR­-CX220 Display Screen Replacement: passo 4, immagine 3 di 3
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Display Screen Replacement: passo 5, immagine 1 di 1
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  6. Sony Handycam HDR­-CX220 Display Screen Replacement, Display Screen: passo 6, immagine 1 di 2 Sony Handycam HDR­-CX220 Display Screen Replacement, Display Screen: passo 6, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remover the two (5mm) screws on the outer part and one (3mm) in the middle.
    • In the second image, there is a second screw on the opposite side of the screen hinge. This screw is not shown, but must also be removed.
  7. Sony Handycam HDR­-CX220 Display Screen Replacement: passo 7, immagine 1 di 1
    • Use the plastic opening tool to remove the plastic case protecting the screen
    • Pull it gently not to damage anything under the case
  8. Sony Handycam HDR­-CX220 Display Screen Replacement: passo 8, immagine 1 di 2 Sony Handycam HDR­-CX220 Display Screen Replacement: passo 8, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remove the 2 screws shown
    • Use your hands to carefully unhook the screen from the highlighted hook
  9. Sony Handycam HDR­-CX220 Display Screen Replacement: passo 9, immagine 1 di 3 Sony Handycam HDR­-CX220 Display Screen Replacement: passo 9, immagine 2 di 3 Sony Handycam HDR­-CX220 Display Screen Replacement: passo 9, immagine 3 di 3
    • Use your hands to carefully remove the tape
    • After removing the tape, pull on the wire disconnecting it from the screen.
Conclusione
Altre 4 persone hanno completato questa guida.
Keven
Membro da: 03/11/16
811 Reputazione
6 Guide realizzate
3 Commenti
How do you mount hdr cx220 lcd cable flat? can you help me?
Rafael Oliveira - Replica
gjhgvnvyh n hygfv
ANM WORLD - Replica
We have a camera 220. Whose dipstick display strip has deteriorated again. Where can I find this strip? Video is good information so that's why
ANM WORLD - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 23
Tutti i Tempi: 2,482
