Introduzione
The replacement of the buttons are necessary if you are struggling to manage through your menus, or having trouble pressing the buttons in general.
Cosa ti serve
Use the Phillips #0 screwdriver to remove the two 5mm screws.
Use the Phillips #0 screwdriver to remove the three 5mm screws.
Use the Philips #0 screwdriver to unscrew the two 5mm screws shown on top of the camera.
Remove the one side 5mm screw using a Philips #0 Screwdriver.
Remove the top buttons from the hook.
Altre 2 persone hanno completato questa guida.
