Introduzione
If something is wrong with the manual eyepiece, use this guide to remove the eyepiece. These problems may include a scratch on the lens or a problem with the extension mechanism.
Cosa ti serve
Remove the six black 4 mm Phillips #00 screws from the bottom panel of the camera.
Pull off the bottom panel. It may be difficult, but tugging on it shouldn't cause harm to yourself or the device.
Remove the two 3 mm Phillips screws directly in front of the zoom button.
Slide the blue copper PCB out of the connector.
Remove the two 3 mm Phillips #00 screws in front of the two screws you removed in the previous step.
Remove the 3 mm Phillips #00 screw to the right of the eyepiece.
Remove the 4 mm Phillips #00 screw to the left of the eyepiece.
