Salta al contenuto principale
Sony Handycam DCR-SR42 Lens Replacement
Cosa ti serve
  1. Sony Handycam DCR-SR42 Lens Replacement, Hard Drive: passo 1, immagine 1 di 2 Sony Handycam DCR-SR42 Lens Replacement, Hard Drive: passo 1, immagine 2 di 2
    • Remove the battery, and use the Phillips #00 precision screwdriver to then remove the three 3mm Phillips #00 screws under the battery.
    • Wait 1 hour after removing the battery before continuing to disassemble the camera.
  2. Sony Handycam DCR-SR42 Lens Replacement: passo 2, immagine 1 di 1
    • Remove the three 3mm #00 Phillips screws on the bottom of the camera.
  3. Sony Handycam DCR-SR42 Lens Replacement: passo 3, immagine 1 di 1
    • Remove the three 3mm Phillips #00 screws on the side of the camera.
    • Remove the 4mm Phillips #00 screw under the AV port cover.
  4. Sony Handycam DCR-SR42 Lens Replacement: passo 4, immagine 1 di 2 Sony Handycam DCR-SR42 Lens Replacement: passo 4, immagine 2 di 2
    • Gently pull the black plastic hard drive cover away from the body of the camera. This will expose the hard drive.
    • Even with all the screws removed, this part will require some force to remove.
  5. Sony Handycam DCR-SR42 Lens Replacement: passo 5, immagine 1 di 2 Sony Handycam DCR-SR42 Lens Replacement: passo 5, immagine 2 di 2
    • Lift the hard drive out of the camera by grasping the grey rubber mounting brackets and pulling them upwards.
    • The hard drive is attached to the flex cable. Remove the hard drive slowly to prevent the flex cable from being damaged.
  6. Sony Handycam DCR-SR42 Lens Replacement: passo 6, immagine 1 di 1
    • Remove the rubber mounting brackets by pulling them off the hard drive.
  7. Sony Handycam DCR-SR42 Lens Replacement: passo 7, immagine 1 di 1
    • Carefully unplug the flex cable from the hard drive.
  8. Sony Handycam DCR-SR42 Lens Replacement, Internal Components: passo 8, immagine 1 di 2 Sony Handycam DCR-SR42 Lens Replacement, Internal Components: passo 8, immagine 2 di 2
    • Remove the four 3mm Phillips #00 screws from under the hard drive.
  9. Sony Handycam DCR-SR42 Lens Replacement: passo 9, immagine 1 di 3 Sony Handycam DCR-SR42 Lens Replacement: passo 9, immagine 2 di 3 Sony Handycam DCR-SR42 Lens Replacement: passo 9, immagine 3 di 3
    • Press in on the two tabs as shown and lift the metal plate up and off the camera.
  10. Sony Handycam DCR-SR42 Lens Replacement: passo 10, immagine 1 di 3 Sony Handycam DCR-SR42 Lens Replacement: passo 10, immagine 2 di 3 Sony Handycam DCR-SR42 Lens Replacement: passo 10, immagine 3 di 3
    • Remove the two 4mm Phillips #00 screws from the underside of the camera.
    • Remove the 2 mm Phillips #00 screw from the screen hinge.
    • Remove the two 6mm Philips #00 screws from the side
  11. Sony Handycam DCR-SR42 Lens Replacement: passo 11, immagine 1 di 3 Sony Handycam DCR-SR42 Lens Replacement: passo 11, immagine 2 di 3 Sony Handycam DCR-SR42 Lens Replacement: passo 11, immagine 3 di 3
    • Use the plastic opening tool to remove the plastic cover from the top of the camera.
    • Remove the two 3mm Phillips #00 screws from underneath the plastic cover.
  12. Sony Handycam DCR-SR42 Lens Replacement: passo 12, immagine 1 di 2 Sony Handycam DCR-SR42 Lens Replacement: passo 12, immagine 2 di 2
    • Remove the second plastic cover from the top of the camera.
    • Remove the 4mm Phillips #00 screw from underneath the cover.
  13. Sony Handycam DCR-SR42 Lens Replacement: passo 13, immagine 1 di 2 Sony Handycam DCR-SR42 Lens Replacement: passo 13, immagine 2 di 2
    • Carefully pry the screen assembly apart from the main body of the camera.
    • Unplug the flex cable from the screen assembly.
  14. Sony Handycam DCR-SR42 Lens Replacement, Lens: passo 14, immagine 1 di 1
    • Remove the 3mm Phillips #00 screw from the underside of the camera near the lens housing.
  15. Sony Handycam DCR-SR42 Lens Replacement: passo 15, immagine 1 di 2 Sony Handycam DCR-SR42 Lens Replacement: passo 15, immagine 2 di 2
    • Use the plastic opening tool to pry the side casing off the camera.
  16. Sony Handycam DCR-SR42 Lens Replacement: passo 16, immagine 1 di 1
    • Remove the final 3mm #00 Phillips screw from the lens housing.
  17. Sony Handycam DCR-SR42 Lens Replacement: passo 17, immagine 1 di 1
    • Remove the lens housing from the camera.
  18. Sony Handycam DCR-SR42 Lens Replacement: passo 18, immagine 1 di 1
    • Remove the three 2mm Phillips #00 screws from around the lens.
  19. Sony Handycam DCR-SR42 Lens Replacement: passo 19, immagine 1 di 1
    • Remove the lens from the camera.
Conclusione
Dan Muller
Membro da: 03/23/15
1.020 Reputazione
5 Guide realizzate
Baylor, Team 7-13, Williams Spring 2015 Membro di Baylor, Team 7-13, Williams Spring 2015
BU-WILLIAMS-S15S7G13
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 790
