Introduzione
The hard drive is one of the most important parts of the camera, but can be easily damaged by being shaken, exposed to liquid or extreme temperatures, or exposed to magnetic fields. The hard drive may also wear out over time. A defective or broken hard drive may prevent the camera from turning on, recording images, or connecting to a computer and transferring files.
Luckily, replacing the hard drive of the DCR-SR42 is a simple procedure that will take no more than 20 minutes. However, the user should be careful when disassembling the camera in order to avoid damaging the flex cable or any other internal components of the camera. The user should also ensure that the battery is disconnected from the camera at least an hour before disassembly is attempted, since capacitors inside the camera can remain charged with electricity some time after the battery is removed. It is necessary to allow capacitors to discharge to prevent injury to the user or damage to the camera.
For problems pertaining to the hard drive, please refer to the Sony Handycam DCR SR-42 Troubleshooting Guide
Cosa ti serve
Remove the battery, and use the Phillips #00 precision screwdriver to then remove the three 3mm Phillips #00 screws under the battery.
Altre 5 persone hanno completato questa guida.
2 Commenti
Gracias por el post. Muy buenas las explicaciones.
Una consulta.
Tengo filmadora SONY DRC-SR21 cuyo disco original es Toshiba MKL8034GAL.
Puedo usar un disco de 30GB para reemplazarlo ?
Intenté hacerlo pero al encender la filmadora, vuelve a apagarse.
El disco original es de 500mA y el de 30GB es de 400mA.
Gracias por la ayuda
Hi, that’s a very comprehensive tutorial, well done!
I’m trying to find out if I can access video footage recorded onto a sony handycam ( DCR-SR75) The LCD screen stopped working and I can’t seem to operate the memory. I would appreciate any advise or suggestions as how to sort this problem thanks, Ger
