Salta al contenuto principale
Sony Handycam DCR-SR42 Hard Drive Replacement
Cosa ti serve
  1. Sony Handycam DCR-SR42 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 2 Sony Handycam DCR-SR42 Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 2
    • Remove the battery, and use the Phillips #00 precision screwdriver to then remove the three 3mm Phillips #00 screws under the battery.
    • Wait 1 hour after removing the battery before continuing to disassemble the camera.
  2. Sony Handycam DCR-SR42 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Remove the three 3mm #00 Phillips screws on the bottom of the camera.
  3. Sony Handycam DCR-SR42 Hard Drive Replacement: passo 3, immagine 1 di 1
    • Remove the three 3mm Phillips #00 screws on the side of the camera.
    • Remove the 4mm Phillips #00 screw under the AV port cover.
  4. Sony Handycam DCR-SR42 Hard Drive Replacement: passo 4, immagine 1 di 2 Sony Handycam DCR-SR42 Hard Drive Replacement: passo 4, immagine 2 di 2
    • Gently pull the black plastic hard drive cover away from the body of the camera. This will expose the hard drive.
    • Even with all the screws removed, this part will require some force to remove.
  5. Sony Handycam DCR-SR42 Hard Drive Replacement: passo 5, immagine 1 di 2 Sony Handycam DCR-SR42 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Lift the hard drive out of the camera by grasping the grey rubber mounting brackets and pulling them upwards.
    • The hard drive is attached to the flex cable. Remove the hard drive slowly to prevent the flex cable from being damaged.
  6. Sony Handycam DCR-SR42 Hard Drive Replacement: passo 6, immagine 1 di 1
    • Remove the rubber mounting brackets by pulling them off the hard drive.
  7. Sony Handycam DCR-SR42 Hard Drive Replacement: passo 7, immagine 1 di 1
    • Carefully unplug the flex cable from the hard drive.
Conclusione
Altre 7 persone hanno completato questa guida.
Dan Muller
Membro da: 03/23/15
1.128 Reputazione
5 Guide realizzate
Baylor, Team 7-13, Williams Spring 2015 Membro di Baylor, Team 7-13, Williams Spring 2015
BU-WILLIAMS-S15S7G13
4 Membri
10 Guide realizzate
4 Commenti
Gracias por el post. Muy buenas las explicaciones.
Una consulta.
Tengo filmadora SONY DRC-SR21 cuyo disco original es Toshiba MKL8034GAL.
Puedo usar un disco de 30GB para reemplazarlo ?
Intenté hacerlo pero al encender la filmadora, vuelve a apagarse.
El disco original es de 500mA y el de 30GB es de 400mA.
Gracias por la ayuda
JORGE - Replica
Hi, that’s a very comprehensive tutorial, well done!
I’m trying to find out if I can access video footage recorded onto a sony handycam ( DCR-SR75) The LCD screen stopped working and I can’t seem to operate the memory. I would appreciate any advise or suggestions as how to sort this problem thanks, Ger
Ger O'Neill - Replica
Any recommendations on bigger drives to replace it with? SSD?
Dave Thomas - Replica
Where can I buy a replacement hdd to do this repair with?
Mark Lawrence - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 60
Tutti i Tempi: 6,845
