Salta al contenuto principale
Sony Handycam DCR-SR 47 Speaker Replacement
Cosa ti serve
  1. Sony Handycam DCR-SR 47 Speaker Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Remove the battery.
    • Use Philips #000 screwdriver to remove the 3mm screw under the battery
    • *t is recommended that you wait One Hour after removing the battery before disassembling the rest of the camera
  2. Sony Handycam DCR-SR 47 Speaker Replacement: passo 2, immagine 1 di 1
    • Using the Phillips #000 screwdriver, remove all 6 of the 3mm screws located on the side of the camera.
    • This step seems unnecessary to initially find the Hard Drive, but will allow access to the attached flex cable
  3. Sony Handycam DCR-SR 47 Speaker Replacement: passo 3, immagine 1 di 1
    • Using the Phillips #000 tool, remove the three 3mm screws from under the LCD screen
  4. Sony Handycam DCR-SR 47 Speaker Replacement: passo 4, immagine 1 di 2 Sony Handycam DCR-SR 47 Speaker Replacement: passo 4, immagine 2 di 2
    • Using the Phillips #000 screwdriver, remove the one 3mm screw on the back of the camera
    • Pull away the back shell of the camera, exposing the hard drive.
  5. Sony Handycam DCR-SR 47 Speaker Replacement: passo 5, immagine 1 di 3 Sony Handycam DCR-SR 47 Speaker Replacement: passo 5, immagine 2 di 3 Sony Handycam DCR-SR 47 Speaker Replacement: passo 5, immagine 3 di 3
    • Gently pull the flex cable away from the hard drive. It should pop-off with minimal effort.
    • The black guard has been removed in the first picture. The guard does not need to be removed in order to reach hard drive and cable, but it does show the path that the cable takes
    • Once removing the flex cable, remove the plastic guard from the side of the hard drive.
  6. Sony Handycam DCR-SR 47 Speaker Replacement, Speaker: passo 6, immagine 1 di 2 Sony Handycam DCR-SR 47 Speaker Replacement, Speaker: passo 6, immagine 2 di 2
    • Using the Phillips #000 screwdriver, remove the four screws from the housing under the hard drive.
    • Remove the top plastic housing of the camera. All screws attaching the housing have previously been removed.
  7. Sony Handycam DCR-SR 47 Speaker Replacement: passo 7, immagine 1 di 3 Sony Handycam DCR-SR 47 Speaker Replacement: passo 7, immagine 2 di 3 Sony Handycam DCR-SR 47 Speaker Replacement: passo 7, immagine 3 di 3
    • Using the Phillips #000 screwdriver, remove the two 3mm screws from the LCD Screen connector and the two 3mm screws on the front plate of the camera
    • Remove the two 3mm screws that were exposed through the previous image
    • Carefully detach the LCD Screen from the rest of the camera.
  8. Sony Handycam DCR-SR 47 Speaker Replacement: passo 8, immagine 1 di 1
    • Carefully remove the lens covering from the camera in order to access the internal components
  9. Sony Handycam DCR-SR 47 Speaker Replacement: passo 9, immagine 1 di 2 Sony Handycam DCR-SR 47 Speaker Replacement: passo 9, immagine 2 di 2
    • Using the spudger, remove the top housing where the hard drive was located.
  10. Sony Handycam DCR-SR 47 Speaker Replacement: passo 10, immagine 1 di 2 Sony Handycam DCR-SR 47 Speaker Replacement: passo 10, immagine 2 di 2
    • Using the #000 Phillips Screwdriver, remove the one 3mm screw holding the speaker housing
    • Once the screw is removed, the speaker can be separated from the camcorder
  11. Sony Handycam DCR-SR 47 Speaker Replacement: passo 11, immagine 1 di 1
    • The speaker is now removed, and the speaker port is open. Replace the new speaker with the damaged one, and replace the one 3mm screw
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 252
