Salta al contenuto principale
Sony Handycam DCR-DVD103 Laser Disc Replacement
Cosa ti serve
  1. Sony Handycam DCR-DVD103 Laser Disc Replacement, Battery: passo 1, immagine 1 di 1
    • Images do not show the camera's battery.
    • On the back of the camera beneath the viewfinder, locate the battery pack.
    • Press the small button.
    • Slide the switch forward.
  2. Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 2, immagine 1 di 1
    • Remove the battery from the camera.
    • To reinsert the battery, slide the battery into the camera.
  3. Sony Handycam DCR-DVD103 Laser Disc Replacement, Outer Cover: passo 3, immagine 1 di 1
    • Using a #00 Phillips screwdriver, remove the six 4.5 mm screws from the camera's bottom.
  4. Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 4, immagine 1 di 2 Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 4, immagine 2 di 2
    • Remove the three 4.5 mm screws beneath the battery.
    • Remove the 2.9 mm screw from the right corner.
    • Remove the two 4.5 mm screws from the battery's right wall.
    • Images do not show the battery.
  5. Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 5, immagine 1 di 1
    • Remove the 4.5 mm screw under the output flap on the front of the camera below the lens.
  6. Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 6, immagine 1 di 2 Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 6, immagine 2 di 2
    • Remove the two 4.5 mm screws at the top of the camera.
    • Remove the 4.5 mm screw from the disk side of the camera (next to the lens).
  7. Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 7, immagine 1 di 2 Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 7, immagine 2 di 2
    • Extend the gray viewfinder, then gently remove the black plastic casing.
    • Caution: Plastic pieces are fragile.
  8. Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 8, immagine 1 di 1
    • Remove the two 2.9 mm screws under the black plastic casing.
  9. Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 9, immagine 1 di 1
    • Gently pull apart the outer silver case and screen.
    • Remove the copper wire strip to detach the case from the camera.
  10. Sony Handycam DCR-DVD103 Laser Disc Replacement, Laser Disc: passo 10, immagine 1 di 3 Sony Handycam DCR-DVD103 Laser Disc Replacement, Laser Disc: passo 10, immagine 2 di 3 Sony Handycam DCR-DVD103 Laser Disc Replacement, Laser Disc: passo 10, immagine 3 di 3
    • Remove (1) 2.9mm screw from under the eye piece.
    • Remove (1) 2.9mm screw from above the eye piece.
    • Remove (4) copper strips from bellow the eye piece.
    • Pull off the eye piece assembly.
  11. Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 11, immagine 1 di 1
    • Pull off back cover. Caution: Be careful not to tear any copper strips in the process.
    • Remove (4) copper strips in order to pull off eye piece.
  12. Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 12, immagine 1 di 1
    • Remove (4) 3.6mm wide head screws on the laser reader.
    • Note: There are rubber rings around screws that easily fall off.
  13. Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 13, immagine 1 di 3 Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 13, immagine 2 di 3 Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 13, immagine 3 di 3
    • Unplug copper strip and lift up.
    • Pull off tape over 2.3mm screw.
    • Remove (1) 2.3mm screw from under the tape.
  14. Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 14, immagine 1 di 2 Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 14, immagine 2 di 2
    • Pull the copper strip, marked by the red rectangle, through the hole behind it, marked with the yellow rectangle.
  15. Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 15, immagine 1 di 3 Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 15, immagine 2 di 3 Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 15, immagine 3 di 3
    • Remove (3) 2.9mm screws from top circuit board.
    • Note: Circuit board will resist trying to be pulled off so pull it off with care but still firmly.
    • Lift up circuit board and remove (1) 2.9mm screw underneath.
    • Pull out copper plate with rubber insulator on it.
  16. Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 16, immagine 1 di 3 Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 16, immagine 2 di 3 Sony Handycam DCR-DVD103 Laser Disc Replacement: passo 16, immagine 3 di 3
    • Remove tape over copper strip in the bottom left corner and pull out copper strip.
    • Remove laser reader assembly.
Conclusione
Lauren
Membro da: 01/05/11
253 Reputazione
2 Guide realizzate
Cal Poly, Team 7-44, Regan Winter 2011 Membro di Cal Poly, Team 7-44, Regan Winter 2011
CPSU-REGAN-W11S7G44
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 22
Tutti i Tempi: 3,423
