Salta al contenuto principale
Sony H.ear On 2 Charging Port Replacement
Cosa ti serve
  1. Sony H.ear On 2 Charging Port Replacement, Ear Cup: passo 1, immagine 1 di 2 Sony H.ear On 2 Charging Port Replacement, Ear Cup: passo 1, immagine 2 di 2
    • Start by inserting the iFixit plastic opening tool in the crease between the hard plastic and the ear cup, and then gently apply pressure until it separates. You may need to repeat the process on back until it is completely separate.
    • This may take a considerable amount of pressure, but do not force it.
  2. Sony H.ear On 2 Charging Port Replacement: passo 2, immagine 1 di 2 Sony H.ear On 2 Charging Port Replacement: passo 2, immagine 2 di 2
    • Use the JIS #00 Screwdriver to remove the five 6.4 mm screws holding the back plastic cover in place.
    • Then, turn the ear cup over and carefully lift the plastic cap off to reveal the internal components of the left ear cup.
    • This same process can be repeated on the right ear cup as well. Be aware the right cup is connected to the rest of the headphones via ribbon cable.
  3. Sony H.ear On 2 Charging Port Replacement, Charging Port: passo 3, immagine 1 di 2 Sony H.ear On 2 Charging Port Replacement, Charging Port: passo 3, immagine 2 di 2
    • Unscrew the single 6.4mm screw holding the IO board / charging board in place using the same JIS #00 screwdriver.
    • Lift out the board carefully, allowing the port to slide out of its holding easily.
    • You will need to wiggle the board back and forth to remove it from its place.
    • Be careful not to tear the ribbon connector holding the board in place. We will be removing it in the next step.
  4. Sony H.ear On 2 Charging Port Replacement: passo 4, immagine 1 di 3 Sony H.ear On 2 Charging Port Replacement: passo 4, immagine 2 di 3 Sony H.ear On 2 Charging Port Replacement: passo 4, immagine 3 di 3
    • Now that you have the IO board removed from its housing, carefully pull the blue ribbon connector from the plastic locking mechanism holding it to the board.
    • Be gentle so you don't tear that connector. It is delicate and you will need it to reconnect to your replacement board.
Linea Traguardo
Altre 7 persone hanno completato questa guida.
Alec Saffer
Membro da: 04/15/19
522 Reputazione
2 Guide realizzate
Cal Poly, Team S9-G11, Maness Spring 2019 Membro di Cal Poly, Team S9-G11, Maness Spring 2019
CPSU-MANESS-S19S9G11
5 Membri
16 Guide realizzate
5 Commenti
How much internal space is there inside the left ear cup? I’m considering attempting to mod my pair with a qi receiver possibly at the expense of the NFC chip.
Finn Atkinson - Replica
I cannot locate the IO board online. Is there somewhere you buy this board?
Jonathon Ingraham - Replica
I have the same question Jonathon, IO board is nowhere to be found online :/
sage.peter - Replica
The IO board looks to be part A-2182-326-A = "Sony L Jack Mounted Pc Board (Uc)". Is that correct?
flash - Replica
where can i find a replacement port?
Pass217 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 40
Tutti i Tempi: 3,726
