Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
This guide shows how to remove the Motherboard.
Parti
Nessuna parte specificata.
  1. To remove the back cover, use your thumb to press down on the center of case and slide it off.
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Using a fingernail lift the battery out of the phone.
    • Using a fingernail lift the battery out of the phone.
  3. Slide the sim card out with your thumb.
    • Slide the sim card out with your thumb.
  4. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  5. To remove the back case first remove the four screws shown with a T5 Torx screwdriver
    • To remove the back case first remove the four screws shown with a T5 Torx screwdriver
  6. Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
    • Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
  7. Lift up towards the bottom and slide the case off.
    • Lift up towards the bottom and slide the case off.
  8. Use a plastic opening tool to lift up the brass colored panel.
    • Use a plastic opening tool to lift up the brass colored panel.
  9. Flip up the yellow tab using a plastic opening tool to disconnect the motherboard from the phone body.
    • Flip up the yellow tab using a plastic opening tool to disconnect the motherboard from the phone body.
  10. Work the plastic opening tool around the edges of the motherboard to release it from the clips.
    • Work the plastic opening tool around the edges of the motherboard to release it from the clips.
Conclusione
Alex Serventi
Membro da: 07/10/2010
50 Reputazione
13 Guide realizzate
Cal Poly, Team 5-15, Maness Fall 2010 Membro di Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 Membri
26 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,037
