Salta al contenuto principale
Introduzione
This guide shows how to remove the Front Speaker.
Parti
Nessuna parte specificata.
  1. To remove the back cover, use your thumb to press down on the center of case and slide it off.
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Using a fingernail lift the battery out of the phone.
    • Using a fingernail lift the battery out of the phone.
  3. To remove the front cover, lift up the case with a fingernail in the small slot as shown.
    • To remove the front cover, lift up the case with a fingernail in the small slot as shown.
  4. To remove the front grey case, remove the two screws shown with a T5 Torx Screwdriver.
    • To remove the front grey case, remove the two screws shown with a T5 Torx Screwdriver.
  5. Batterie per PC portatili
    Batterie per tutti i migliori marchi di PC, supportate dalla nostra Garanzia di Qualità.
    Acquista ora
    Acquista ora
  6. Pry up the dark grey case with your fingernail until all four snaps around the top are loose.
    • Pry up the dark grey case with your fingernail until all four snaps around the top are loose.
  7. Lift up towards the bottom and slide the case off.
    • Lift up towards the bottom and slide the case off.
  8. Use a plastic opening tool to lift the black tape off of the ribbon cable connector.
    • Use a plastic opening tool to lift the black tape off of the ribbon cable connector.
  9. Lift the ribbon cable connector lock using a plastic opening tool.
    • Lift the ribbon cable connector lock using a plastic opening tool.
  10. Slide the black ribbon cable tray out with a plastic opening tool. Shown in the second picture is the try already slid out.
    • Slide the black ribbon cable tray out with a plastic opening tool.
    • Shown in the second picture is the try already slid out.
  11. Slide the ribbon cable out of the connector. Shown in the second picture is the cable already out.
    • Slide the ribbon cable out of the connector.
    • Shown in the second picture is the cable already out.
  12. Use a plastic opening tool to lift up on the screen board and release the clips holding it in place.
    • Use a plastic opening tool to lift up on the screen board and release the clips holding it in place.
    • Lift the entire board out of the phone to remove both screens.
  13. Use a plastic opening tool to lift the speaker out of its circular slot.
    • Use a plastic opening tool to lift the speaker out of its circular slot.
Conclusione
Alex Serventi
Membro da: 07/10/2010
50 Reputazione
13 Guide realizzate
Cal Poly, Team 5-15, Maness Fall 2010 Membro di Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 Membri
26 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,453
