Salta al contenuto principale
Sony Ericsson xPeria Active Speaker Replacement
Cosa ti serve
  1. Sony Ericsson xPeria Active Speaker Replacement, Remove the back cover.: passo 1, immagine 1 di 3 Sony Ericsson xPeria Active Speaker Replacement, Remove the back cover.: passo 1, immagine 2 di 3 Sony Ericsson xPeria Active Speaker Replacement, Remove the back cover.: passo 1, immagine 3 di 3
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Sony Ericsson xPeria Active Speaker Replacement, Remove inside plastic battery cover.: passo 2, immagine 1 di 2 Sony Ericsson xPeria Active Speaker Replacement, Remove inside plastic battery cover.: passo 2, immagine 2 di 2
    • Remove the battery shield with the plastic opening device.
  3. Sony Ericsson xPeria Active Speaker Replacement, Remove the battery: passo 3, immagine 1 di 2 Sony Ericsson xPeria Active Speaker Replacement, Remove the battery: passo 3, immagine 2 di 2
    • Remove the battery.
  4. Sony Ericsson xPeria Active Speaker Replacement, Unfastening The Motherboard Cover: passo 4, immagine 1 di 1
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  5. Sony Ericsson xPeria Active Speaker Replacement, Removing The Motherboard Cover: passo 5, immagine 1 di 2 Sony Ericsson xPeria Active Speaker Replacement, Removing The Motherboard Cover: passo 5, immagine 2 di 2
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
  6. Sony Ericsson xPeria Active Speaker Replacement, Speaker: passo 6, immagine 1 di 2 Sony Ericsson xPeria Active Speaker Replacement, Speaker: passo 6, immagine 2 di 2
    • Carefully pry the power cable away from the motherboard.
  7. Sony Ericsson xPeria Active Speaker Replacement: passo 7, immagine 1 di 1
    • Pry the motherboard out of the case.
  8. Sony Ericsson xPeria Active Speaker Replacement: passo 8, immagine 1 di 1
    • Remove the power cable from the backside of the motherboard.
  9. Sony Ericsson xPeria Active Speaker Replacement: passo 9, immagine 1 di 1
    • The speaker can be seen in the top middle area on the reverse of the screen.
  10. Sony Ericsson xPeria Active Speaker Replacement: passo 10, immagine 1 di 1
    • Use the plastic opening tool to carefully pry the speaker away from the phone.
Conclusione
Altre 2 persone hanno completato questa guida.
Daniel
Membro da: 10/13/14
437 Reputazione
2 Guide realizzate
USF Tampa, Team 14-5, Leahy Fall 2014 Membro di USF Tampa, Team 14-5, Leahy Fall 2014
USFT-LEAHY-F14S14G5
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 11
Tutti i Tempi: 862
