Salta al contenuto principale
Sony Ericsson xPeria Active Screen Replacement
Cosa ti serve
  1. Sony Ericsson xPeria Active Screen Replacement, Remove the back cover.: passo 1, immagine 1 di 3 Sony Ericsson xPeria Active Screen Replacement, Remove the back cover.: passo 1, immagine 2 di 3 Sony Ericsson xPeria Active Screen Replacement, Remove the back cover.: passo 1, immagine 3 di 3
    • Open the flaps and remove the back cover using the plastic opening device.
  2. Sony Ericsson xPeria Active Screen Replacement, Remove inside plastic battery cover.: passo 2, immagine 1 di 2 Sony Ericsson xPeria Active Screen Replacement, Remove inside plastic battery cover.: passo 2, immagine 2 di 2
    • Remove the battery shield with the plastic opening device.
  3. Sony Ericsson xPeria Active Screen Replacement, Remove the battery: passo 3, immagine 1 di 2 Sony Ericsson xPeria Active Screen Replacement, Remove the battery: passo 3, immagine 2 di 2
    • Remove the battery.
  4. Sony Ericsson xPeria Active Screen Replacement, Unfastening The Motherboard Cover: passo 4, immagine 1 di 1
    • Unscrew the 5mm screws with the T5 head.
    • Unscrew the 6mm screw with the T6 head.
  5. Sony Ericsson xPeria Active Screen Replacement, Removing The Motherboard Cover: passo 5, immagine 1 di 2 Sony Ericsson xPeria Active Screen Replacement, Removing The Motherboard Cover: passo 5, immagine 2 di 2
    • Remove the black cover with the plastic opening tool.
    • Remove the headphone jack from its slot.
  6. Sony Ericsson xPeria Active Screen Replacement, Screen: passo 6, immagine 1 di 2 Sony Ericsson xPeria Active Screen Replacement, Screen: passo 6, immagine 2 di 2
    • Unplug the power cable by carefully prying it away from the motherboard.
  7. Sony Ericsson xPeria Active Screen Replacement: passo 7, immagine 1 di 2 Sony Ericsson xPeria Active Screen Replacement: passo 7, immagine 2 di 2
    • Remove the power strip on the back side of the motherboard.
  8. Sony Ericsson xPeria Active Screen Replacement, Remove back screen shield: passo 8, immagine 1 di 2 Sony Ericsson xPeria Active Screen Replacement, Remove back screen shield: passo 8, immagine 2 di 2
    • Remove the shield.
  9. Sony Ericsson xPeria Active Screen Replacement, Remove the screen module: passo 9, immagine 1 di 2 Sony Ericsson xPeria Active Screen Replacement, Remove the screen module: passo 9, immagine 2 di 2
    • Push the screen through the front of the case, gently.
    • It may be a little tough, just work your way around the edges of the screen until it separates from the main case.
Conclusione
Altre 5 persone hanno completato questa guida.
Alex Tobin
Membro da: 10/06/14
406 Reputazione
3 Guide realizzate
USF Tampa, Team 14-5, Leahy Fall 2014 Membro di USF Tampa, Team 14-5, Leahy Fall 2014
USFT-LEAHY-F14S14G5
3 Membri
5 Guide realizzate
Un commento
hi can you add explain
abdnour master2 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,336
