Introduzione
The headphone jack will need to be replaced it it no longer outputs audio.
Open the flaps and remove the back cover using the plastic opening device.
  • Open the flaps and remove the back cover using the plastic opening device.
Aggiungi Commento
Remove the battery shield with the plastic opening device.
  • Remove the battery shield with the plastic opening device.
Aggiungi Commento
  • Remove the battery.
Aggiungi Commento
  • Unscrew the 5mm screws with the T5 head.
  • Unscrew the 6mm screw with the T6 head.
Aggiungi Commento
  • Remove the black cover with the plastic opening tool.
  • Remove the headphone jack from its slot.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Daniel
Membro da: 13/10/2014
415 Reputazione
2 Guide realizzate
USF Tampa, Team 14-5, Leahy Fall 2014 Membro di USF Tampa, Team 14-5, Leahy Fall 2014
USFT-LEAHY-F14S14G5
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 514
