Salta al contenuto principale
Introduzione
This guide will show the steps for replacing the Sony Ericsson s710a battery and LCD screen. You can use this guide if the battery or LCD screen has been damaged and needs to be replaced or repaired. This guide can also be used to check the connection between the screen and the motherboard.
  1. Sony Ericsson s710a Battery and LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the back cover by sliding it off.
  2. Sony Ericsson s710a Battery and LCD Screen Replacement: passo 2, immagine 1 di 1
    • Pull the battery out using your finger (as shown).
  3. Sony Ericsson s710a Battery and LCD Screen Replacement: passo 3, immagine 1 di 1
    • The battery can now be replaced.
    • The battery is a 780 mAh rechargeable Lithium Ion battery.
  4. Sony Ericsson s710a Battery and LCD Screen Replacement, LCD Screen: passo 4, immagine 1 di 1
    • Remove the four 6mm Phillips head screws located beneath the battery.
    • Set aside the screws in a designated container so that they can easily be found during reassembly.
  5. Sony Ericsson s710a Battery and LCD Screen Replacement: passo 5, immagine 1 di 1
    • Remove the microphone cover using the iFixit opening tool.
  6. Sony Ericsson s710a Battery and LCD Screen Replacement: passo 6, immagine 1 di 1
    • Remove the two 6mm screws on the front of the phone beneath the microphone cover.
  7. Sony Ericsson s710a Battery and LCD Screen Replacement: passo 7, immagine 1 di 1
    • Remove the black plastic piece on the side.
    • This will allow for easier access while prying the motherboard.
  8. Sony Ericsson s710a Battery and LCD Screen Replacement: passo 8, immagine 1 di 1
    • Use the iFixit opening tool to loosen the motherboard from the phone.
  9. Sony Ericsson s710a Battery and LCD Screen Replacement: passo 9, immagine 1 di 1
    • Lift the motherboard out with your fingers.
    • Pull slowly. This will require some force.
  10. Sony Ericsson s710a Battery and LCD Screen Replacement: passo 10, immagine 1 di 1
    • Remove the two cable connectors using the iFixit opening tool.
    • Mark the orientation and port of each cable before detaching them. The connectors are symmetrical, so this is essential for reassembly.
    • Place the motherboard aside in a safe location.
  11. Sony Ericsson s710a Battery and LCD Screen Replacement: passo 11, immagine 1 di 1
    • On the rotational assembly.
    • Unscrew the four 3mm screws
    • Unscrew the two 2.3mm screws
    • Remember to keep the screws grouped away from the other screws in the device.
    • Lift the rotational assembly off of the phone to allow access to the other half of the device.
  12. Sony Ericsson s710a Battery and LCD Screen Replacement: passo 12, immagine 1 di 1
    • Detach the cable connectors on the other end of the cables using a plastic opening tool.
    • Record the orientation and location of each connector.
  13. Sony Ericsson s710a Battery and LCD Screen Replacement: passo 13, immagine 1 di 1
    • Remove the plastic cover on the back of the phone using a plastic opening tool.
    • Remove the two 6mm screws.
  14. Sony Ericsson s710a Battery and LCD Screen Replacement: passo 14, immagine 1 di 1
    • Pry the screen assembly from the main case using the iFixit opening tool.
  15. Sony Ericsson s710a Battery and LCD Screen Replacement: passo 15, immagine 1 di 1
    • With the face plate and LCD screen exposed, replace the existing LCD screen with a new LCD screen.
    • Be sure to test and make sure the detachable connections are arranged correctly.
Conclusione
Jamel Lugg
Membro da: 29/10/2011
1 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,419
