Salta al contenuto principale
Sony Ericsson s710a LCD Screen Replacement
Cosa ti serve
  1. Sony Ericsson s710a LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the back cover by sliding it off.
  2. Sony Ericsson s710a LCD Screen Replacement: passo 2, immagine 1 di 1
    • Pull the battery out using your finger.
  3. Sony Ericsson s710a LCD Screen Replacement: passo 3, immagine 1 di 1
    • The battery can now be replaced.
    • The battery is a 780 mAh rechargeable Lithium Ion battery.
  4. Sony Ericsson s710a LCD Screen Replacement, LCD Screen: passo 4, immagine 1 di 1
    • Remove the four 6 mm screws from beneath the battery using a Phillips #00 screwdriver.
  5. Sony Ericsson s710a LCD Screen Replacement: passo 5, immagine 1 di 1
    • Remove the microphone cover using the iFixit opening tool.
  6. Sony Ericsson s710a LCD Screen Replacement: passo 6, immagine 1 di 1
    • Remove the two 6 mm screws from the front of the phone beneath the microphone cover using a Phillips #00 screwdriver.
  7. Sony Ericsson s710a LCD Screen Replacement: passo 7, immagine 1 di 1
    • Remove the black plastic piece on the side.
    • This will allow for easier access while prying the motherboard.
  8. Sony Ericsson s710a LCD Screen Replacement: passo 8, immagine 1 di 1
    • Use the iFixit opening tool to loosen the motherboard from the phone.
  9. Sony Ericsson s710a LCD Screen Replacement: passo 9, immagine 1 di 1
    • Lift the motherboard out with your fingers.
    • Pull slowly. This will require some force.
  10. Sony Ericsson s710a LCD Screen Replacement: passo 10, immagine 1 di 1
    • Remove the two cable connectors using the iFixit opening tool.
    • Mark the orientation and port of each cable before detaching them. The connectors are symmetrical, so this is essential for reassembly.
  11. Sony Ericsson s710a LCD Screen Replacement: passo 11, immagine 1 di 1
    • On the rotational assembly remove the following screws:
    • Four 3 mm screws
    • Two 2.3 mm screws
    • Lift the rotational assembly off of the phone to allow access to the other half of the device.
  12. Sony Ericsson s710a LCD Screen Replacement: passo 12, immagine 1 di 1
    • Detach the cable connectors on the other end of the cables using a plastic opening tool.
    • Record the orientation and location of each connector for reassembly.
  13. Sony Ericsson s710a LCD Screen Replacement: passo 13, immagine 1 di 1
    • Remove the plastic cover on the back of the phone using an iFixit opening tool.
    • Remove the four 6 mm screws using a Phillips #00 screwdriver.
  14. Sony Ericsson s710a LCD Screen Replacement: passo 14, immagine 1 di 1
    • Pry the screen assembly from the main case using the iFixit opening tool.
  15. Sony Ericsson s710a LCD Screen Replacement: passo 15, immagine 1 di 1
    • With the face plate and LCD screen exposed, replace the existing LCD screen with a new LCD screen.
    • Be sure to test and make sure the detachable connections are arranged correctly.
Conclusione
Jamel Lugg
Membro da: 10/29/11
1 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,470
