Salta al contenuto principale
Introduzione
This guide will show you how to access and replace the Sony Ericsson s710a battery and main keypad. Use this guide if the battery needs to be replaced or the keypad needs to be cleaned or repaired. You can also remove the keypad, decorate it, and have your phone stand apart from the crowd.
  1. Sony Ericsson s710a Battery and Keypad Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the back cover by sliding it off.
  2. Sony Ericsson s710a Battery and Keypad Replacement: passo 2, immagine 1 di 1
    • Pull the battery out using your finger (as shown).
  3. Sony Ericsson s710a Battery and Keypad Replacement: passo 3, immagine 1 di 1
    • The battery can now be replaced.
    • The battery is a 780 mAh rechargeable Lithium Ion battery.
  4. Sony Ericsson s710a Battery and Keypad Replacement, Keypad: passo 4, immagine 1 di 1
    • Remove the four marked screws in the photograph with the screw driver.
  5. Sony Ericsson s710a Battery and Keypad Replacement: passo 5, immagine 1 di 1
    • Remove the plastic cover with the iFixit opening tool.
    • It is easiest to begin at the SD card slot and alternate prying the cover on opposite sides.
    • The cover will not come off completely, because there are additional screws that need to be removed, but will pry loose up to the camera.
  6. Sony Ericsson s710a Battery and Keypad Replacement: passo 6, immagine 1 di 1
    • Using the iFixit opening tool, pry off the plastic piece at the bottom of the keypad.
    • This piece is fixed with an adhesive, so you must break the bond to reach the screws underneath. It may be necessary to use additional adhesive during reassembly.
  7. Sony Ericsson s710a Battery and Keypad Replacement: passo 7, immagine 1 di 1
    • Unscrew both 6mm screws, beneath the previously removed plastic cover, using a Phillips screwdriver.
    • Completely remove the back plastic cover.
  8. Sony Ericsson s710a Battery and Keypad Replacement: passo 8, immagine 1 di 2 Sony Ericsson s710a Battery and Keypad Replacement: passo 8, immagine 2 di 2
    • Pry the board from the plastic case using the iFixit opening tool.
    • This part is tricky. The black plastic pieces at the base of the phone (marked) hold the board in.
  9. Sony Ericsson s710a Battery and Keypad Replacement: passo 9, immagine 1 di 1
    • After removing the board, you will see the plastic keyboard beneath. This can be removed by hand and is very flexible.
    • You have successfully removed the keypad. You can clean, decorate, or replace the keyboard without worrying about damaging the phone.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,283
