Salta al contenuto principale
Sony Ericsson Z500a Logic Board Replacement
Cosa ti serve
  1. Sony Ericsson Z500a Logic Board Replacement, Keypad: passo 1, immagine 1 di 3 Sony Ericsson Z500a Logic Board Replacement, Keypad: passo 1, immagine 2 di 3 Sony Ericsson Z500a Logic Board Replacement, Keypad: passo 1, immagine 3 di 3
    • Remove the back cover by pulling it down, and then take out the battery.
    • Using a T6 Torx screwdriver, remove the 4 screws.
    • Keep the phone open with the back cover facing you.
  2. Sony Ericsson Z500a Logic Board Replacement: passo 2, immagine 1 di 1
    • Use the plastic opening tool and run it between the case and the body of the device to loosen the keyboard
    • There are 2 clamps that lock the keyboard to the case (1 on each side)
  3. Sony Ericsson Z500a Logic Board Replacement: passo 3, immagine 1 di 1
    • Flip the phone over and lift straight up on the key pad to remove it.
    • Be sure to hold the phone flat (parallel to the table) so that no loose parts fall out.
  4. Sony Ericsson Z500a Logic Board Replacement, Logic Board: passo 4, immagine 1 di 2 Sony Ericsson Z500a Logic Board Replacement, Logic Board: passo 4, immagine 2 di 2
    • Use the opening tool to remove the 2 ribbon wires (boxed in the photo) from the logic board.
    • Gently lift the back of the logic board and then pull outwards. Be careful not to rip the ribbon wire.
  5. Sony Ericsson Z500a Logic Board Replacement: passo 5, immagine 1 di 2 Sony Ericsson Z500a Logic Board Replacement: passo 5, immagine 2 di 2
    • Remove the black sim card reader and green vibrator before continuing to ensure they do not fall out.
Conclusione
Tim
Membro da: 04/20/10
15 Reputazione
2 Guide realizzate
Cal Poly, Team 7-12, Maness Spring 2010 Membro di Cal Poly, Team 7-12, Maness Spring 2010
CPSU-MANESS-S10S7G12
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,652
