Salta al contenuto principale
Fix Your Stuff
Right to Repair
Parts & Tools
Introduzione
Sony Ericsson X10 - how to disassemble the phone and replace the Touchscreen Glass.
Please SUBSCRIBE to my channel ツ
Panoramica Video
  1. Switch-off the phone. Remove the battery. Unscrew 8x T6 Torx screws.
    • Switch-off the phone.
    • Remove the battery.
    • Unscrew 8x T6 Torx screws.
  2. Use a Plastic Pry or other plastic tool to unhook the back housing / bezel and remove it. Tip - try prying it open from the top and over to the side. It can be very tight if you are doing this for the first time. The volume rocker and camera button are not part of the housing, so try going around it. Tip - try prying it open from the top and over to the side. It can be very tight if you are doing this for the first time. The volume rocker and camera button are not part of the housing, so try going around it.
    • Use a Plastic Pry or other plastic tool to unhook the back housing / bezel and remove it.
    • Tip - try prying it open from the top and over to the side. It can be very tight if you are doing this for the first time. The volume rocker and camera button are not part of the housing, so try going around it.
  3. Remove the Volume Up/Down and Camera buttons. Unhook the SIM & SD Card reader unit and disconnect the flex cable. Unhook the SIM & SD Card reader unit and disconnect the flex cable.
    • Remove the Volume Up/Down and Camera buttons.
    • Unhook the SIM & SD Card reader unit and disconnect the flex cable.
  4. Remove the Audio jack connector. Disconnect 4x flex cables: LCD Display
    • Remove the Audio jack connector.
    • Disconnect 4x flex cables:
    • LCD Display
    • Menu buttons
    • Touchscreen
    • Earpiece, Volume & Power On buttons
    • Carefully remove the mother board.
    • Please SUBSCRIBE to my channel ツ
  5. Use a heat gun or a hairdryer and warm the glass. With a cutter carefully make a room between the glass and the frame to insert a Plastic Pick. Slowly separate the Touchscreen from the frame.
    • Use a heat gun or a hairdryer and warm the glass.
    • With a cutter carefully make a room between the glass and the frame to insert a Plastic Pick.
    • Slowly separate the Touchscreen from the frame.
  6. When you are installing the new Touchscreen you must use an adhesive tape. .
Conclusione
ZFix
Membro da: 09/12/2013
168.494 Reputazione
306 Guide realizzate
Master Techs Membro di Master Techs
Community
291 Membri
831 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,503
