Salta al contenuto principale
Sony Ericsson Xperia X10 Logic Board Replacement
Cosa ti serve
Panoramica Video
  1. Sony Ericsson Xperia X10 Logic Board Replacement, Logic Board: passo 1, immagine 1 di 3 Sony Ericsson Xperia X10 Logic Board Replacement, Logic Board: passo 1, immagine 2 di 3 Sony Ericsson Xperia X10 Logic Board Replacement, Logic Board: passo 1, immagine 3 di 3
    • Switch-off the phone.
    • Remove the battery.
    • Unscrew 8x T6 Torx screws.
  2. Sony Ericsson Xperia X10 Logic Board Replacement: passo 2, immagine 1 di 3 Sony Ericsson Xperia X10 Logic Board Replacement: passo 2, immagine 2 di 3 Sony Ericsson Xperia X10 Logic Board Replacement: passo 2, immagine 3 di 3
    • Use a Plastic Pry or other plastic tool to unhook the back housing / bezel and remove it.
    • Tip - try prying it open from the top and over to the side. It can be very tight if you are doing this for the first time. The volume rocker and camera button are not part of the housing, so try going around it.
  3. Sony Ericsson Xperia X10 Logic Board Replacement: passo 3, immagine 1 di 3 Sony Ericsson Xperia X10 Logic Board Replacement: passo 3, immagine 2 di 3 Sony Ericsson Xperia X10 Logic Board Replacement: passo 3, immagine 3 di 3
    • Remove the Volume Up/Down and Camera buttons.
    • Unhook the SIM & SD Card reader unit and disconnect the flex cable.
  4. Sony Ericsson Xperia X10 Logic Board Replacement: passo 4, immagine 1 di 3 Sony Ericsson Xperia X10 Logic Board Replacement: passo 4, immagine 2 di 3 Sony Ericsson Xperia X10 Logic Board Replacement: passo 4, immagine 3 di 3
    • Remove the Audio jack connector.
    • Disconnect 4x flex cables:
    • LCD Display
    • Menu buttons
    • Touchscreen
    • Earpiece, Volume & Power On buttons
    • Carefully remove the mother board.
    • Please SUBSCRIBE to my channel ใƒ„
Conclusione
ZFix
Membro da: 12/09/13
191.278 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.528 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,948
