Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
How to disassemble the phone and replace LCD Display.
Please SUBSCRIBE to my channel ツ
Panoramica Video
  1. Switch-off the phone. Remove the battery. Unscrew 8x T6 Torx screws.
    • Switch-off the phone.
    • Remove the battery.
    • Unscrew 8x T6 Torx screws.
  2. Use a Plastic Pry or other plastic tool to unhook the back housing / bezel and remove it. Tip - try prying it open from the top and over to the side. It can be very tight if you are doing this for the first time. The volume rocker and camera button are not part of the housing, so try going around it. Tip - try prying it open from the top and over to the side. It can be very tight if you are doing this for the first time. The volume rocker and camera button are not part of the housing, so try going around it.
    • Use a Plastic Pry or other plastic tool to unhook the back housing / bezel and remove it.
    • Tip - try prying it open from the top and over to the side. It can be very tight if you are doing this for the first time. The volume rocker and camera button are not part of the housing, so try going around it.
  3. Remove the Volume Up/Down and Camera buttons. Unhook the SIM & SD Card reader unit and disconnect the flex cable. Unhook the SIM & SD Card reader unit and disconnect the flex cable.
    • Remove the Volume Up/Down and Camera buttons.
    • Unhook the SIM & SD Card reader unit and disconnect the flex cable.
  4. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  5. Remove the Audio jack connector. Disconnect 4x flex cables: LCD Display
    • Remove the Audio jack connector.
    • Disconnect 4x flex cables:
    • LCD Display
    • Menu buttons
    • Touchscreen
    • Earpiece, Volume & Power On buttons
    • Carefully remove the mother board.
    • Please SUBSCRIBE to my channel ツ
  6. Unstuck the Touchscreen flex cable from the LCD Display Frame. Use only plastic tools for this operation to avoid damage to the cable. You can use hot air to make the separation easier.
    • Unstuck the Touchscreen flex cable from the LCD Display Frame.
    • Use only plastic tools for this operation to avoid damage to the cable.
    • You can use hot air to make the separation easier.
    • Disassemble the Home buttons flex cable & Plastic Bracket to release the Touchscreen Flex cable.
  7. Use a Plastic Pry or other plastic tool to separate the LCD Display with Frame from the Front Touchscreen Housing. Do this carefully. Do this carefully.
    • Use a Plastic Pry or other plastic tool to separate the LCD Display with Frame from the Front Touchscreen Housing.
    • Do this carefully.
  8. Remove the Menu / Camera buttons flex cable. Use again hot air and carefully unstick the LCD Display flex cable from the frame. Use again hot air and carefully unstick the LCD Display flex cable from the frame.
    • Remove the Menu / Camera buttons flex cable.
    • Use again hot air and carefully unstick the LCD Display flex cable from the frame.
  9. Separate the LCD Display from the Metal Frame. Please SUBSCRIBE to my channel  ツ Please SUBSCRIBE to my channel  ツ
Conclusione
ZFix
Membro da: 09/12/2013
169.763 Reputazione
306 Guide realizzate
Master Techs Membro di Master Techs
Community
293 Membri
841 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 17
Tutti i Tempi: 873
