Salta al contenuto principale
Sony Ericsson Xperia X10 Audio and Camera buttons Replacement
Cosa ti serve
  1. Sony Ericsson Xperia X10 Audio and Camera buttons Replacement, Audio and Camera buttons: passo 1, immagine 1 di 1
    • The first step in accessing the audio and/or camera buttons is to remove the back case of the phone and then the battery
  2. Sony Ericsson Xperia X10 Audio and Camera buttons Replacement: passo 2, immagine 1 di 1
    • Use a Torx T6 screwdriver to remove eight 5 mm screws on the back case.
  3. Sony Ericsson Xperia X10 Audio and Camera buttons Replacement: passo 3, immagine 1 di 1
    • Using an opening case, (a guitar pick works as well), start on the bottom right side of the phone and undo the clips located at the interior sides. Repeat this step for the left side.
  4. Sony Ericsson Xperia X10 Audio and Camera buttons Replacement: passo 4, immagine 1 di 1
    • The phone should now look like this. The Volume button is indicated by the larger yellow circle, and the camera button is indicated by the smaller and lower yellow circle.
  5. Sony Ericsson Xperia X10 Audio and Camera buttons Replacement: passo 5, immagine 1 di 1
    • The volume button (left) and the camera button (right) lift right out of the phone as shown in the picture. From here you can clean them or replace them.
Conclusione
Altre 3 persone hanno completato questa guida.
Nick E
Membro da: 10/29/13
149 Reputazione
1 Guida realizzata
UMass Dartmouth, Team 1-5, Shastany Fall 2013 Membro di UMass Dartmouth, Team 1-5, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G5
2 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,811
