Salta al contenuto principale
Sony Ericsson Xperia Pro MK16A Logic Board Replacement
Cosa ti serve
  1. Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Taking the Back Off: passo 1, immagine 1 di 3 Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Taking the Back Off: passo 1, immagine 2 di 3 Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Taking the Back Off: passo 1, immagine 3 di 3
    • Use a plastic opening tool to get the back cover off your phone.
    • The plastic opener will work on any side, but be careful and pry gently.
  2. Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Removing the Battery: passo 2, immagine 1 di 1
    • Locate the battery in your phone.
    • Find the divot below the battery.
    • Use your thumb to lift the battery out of the phone.
  3. Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Remove Screws: passo 3, immagine 1 di 3 Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Remove Screws: passo 3, immagine 2 di 3 Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Remove Screws: passo 3, immagine 3 di 3
    • Remove the 4 black screws with the Phillips screwdriver.
    • Remove the 4 silver screws with the Torx screwdriver.
  4. Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Remove Back Case: passo 4, immagine 1 di 1
    • Insert the plastic opening tool in between the two halves of the case. Pry around the phone to detach the back case.
  5. Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Access the Logic Board: passo 5, immagine 1 di 3 Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Access the Logic Board: passo 5, immagine 2 di 3 Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Access the Logic Board: passo 5, immagine 3 di 3
    • Remove the last screw that is connecting the logic board using the Phillips screwdriver.
    • Undo the two ribbons.
  6. Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Remove the Logic Board: passo 6, immagine 1 di 3 Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Remove the Logic Board: passo 6, immagine 2 di 3 Sony Ericsson Xperia Pro MK16A Logic Board Replacement, Remove the Logic Board: passo 6, immagine 3 di 3
    • Undo that last connector.
Conclusione
Craig
Membro da: 10/21/14
55 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,105
