Salta al contenuto principale
Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement
Cosa ti serve
Panoramica Video
  1. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: passo 1, immagine 1 di 3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: passo 1, immagine 2 di 3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: passo 1, immagine 3 di 3
    • Remove the battery cover and the battery.
    • Unscrew the 7x black screws and 6x silver screws.
    • Remove the rear bezel.
  2. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 2, immagine 1 di 3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 2, immagine 2 di 3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 2, immagine 3 di 3
    • after removing the 2x black philips screws, use a plastic tool to disconnect the main flex cable connector.
    • Disconnect the gaming keyboard flex cable.
  3. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 3, immagine 1 di 2 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 3, immagine 2 di 2
    • Remove the motherboard and the gaming keyboard.
  4. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 4, immagine 1 di 3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 4, immagine 2 di 3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 4, immagine 3 di 3
    • Remove the 4x philips screws and the small black sticker on the corner.
    • Disconnect the touchscreen flex cable connector.
    • Disassemble the front bezel.
  5. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 5, immagine 1 di 3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 5, immagine 2 di 3 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 5, immagine 3 di 3
    • To separate the touchscreen from the base bezel use hot air and plastic tools.
  6. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 6, immagine 1 di 2 Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 6, immagine 2 di 2
    • Use double side adhesive tape to assemble the touch screen.
  7. Sony Ericsson Xperia Play Touch Screen Glass Digitizer Replacement: passo 7, immagine 1 di 1
Conclusione
ZFix
Membro da: 12/09/13
191.368 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.465 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 27
Tutti i Tempi: 3,224
