Salta al contenuto principale
Sony Ericsson Xperia Play Main Flex Cable Replacement
Cosa ti serve
Panoramica Video
  1. Sony Ericsson Xperia Play Main Flex Cable Replacement, Main Flex Ribbon Cable: passo 1, immagine 1 di 3 Sony Ericsson Xperia Play Main Flex Cable Replacement, Main Flex Ribbon Cable: passo 1, immagine 2 di 3 Sony Ericsson Xperia Play Main Flex Cable Replacement, Main Flex Ribbon Cable: passo 1, immagine 3 di 3
    • Remove the battery cover and the battery.
    • You have 6x silver screw and 7x black screw and remove the rear bezel.
  2. Sony Ericsson Xperia Play Main Flex Cable Replacement: passo 2, immagine 1 di 2 Sony Ericsson Xperia Play Main Flex Cable Replacement: passo 2, immagine 2 di 2
    • Now with a plastic tool disconnect the main flex cable. Be careful, near to the main flex cable connector there is many small elements.
    • Disconnect the gaming keyboard flex keyboard.
  3. Sony Ericsson Xperia Play Main Flex Cable Replacement: passo 3, immagine 1 di 2 Sony Ericsson Xperia Play Main Flex Cable Replacement: passo 3, immagine 2 di 2
    • Remove the mother board and the gaming keyboard.
  4. Sony Ericsson Xperia Play Main Flex Cable Replacement: passo 4, immagine 1 di 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: passo 4, immagine 2 di 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: passo 4, immagine 3 di 3
    • Unscrew the 4x screws.
    • Remove the black sticker.
    • Disconnect the touchscreen flex cable connector.
    • Now you can disassemble the front bezel.
  5. Sony Ericsson Xperia Play Main Flex Cable Replacement: passo 5, immagine 1 di 2 Sony Ericsson Xperia Play Main Flex Cable Replacement: passo 5, immagine 2 di 2
    • Use the thin end of a plastic tool to remove LCD Display and disconnect the flex cable.
  6. Sony Ericsson Xperia Play Main Flex Cable Replacement: passo 6, immagine 1 di 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: passo 6, immagine 2 di 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: passo 6, immagine 3 di 3
    • To release the ribbon cable peel off two patches.
  7. Sony Ericsson Xperia Play Main Flex Cable Replacement: passo 7, immagine 1 di 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: passo 7, immagine 2 di 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: passo 7, immagine 3 di 3
    • Now remove the small metal plate taped to the flex cable.
    • Remove the plastic plate from the back side of the flex cable connector.
    • Bend the cable at an angle so you can push it down through the hole.
  8. Sony Ericsson Xperia Play Main Flex Cable Replacement: passo 8, immagine 1 di 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: passo 8, immagine 2 di 3 Sony Ericsson Xperia Play Main Flex Cable Replacement: passo 8, immagine 3 di 3
    • Use the same technique when you are installing the new Main Ribbon Cable.
    • I prefer to test the new spare part before the full assembly.
  9. Sony Ericsson Xperia Play Main Flex Cable Replacement: passo 9, immagine 1 di 1
Conclusione
Altre 5 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.182 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.521 Guide realizzate
3 Commenti
Iv got a problem my phone won't turn on or charge but when i plug the charger in the power button just flashes red a couple of times then nothing do u know what this means is it the battery or the phone that is broke
paulfrost412 - Replica
Is "small metal plate" from Step 7 important? Forgot to put it inside and if there is no need to open it again (everything works) I won't do it :)
ch3mn3y - Replica
vreau sa cumpar sleif la xperia play, rog foarte muld daca aveti ceva informatii sunati sau scrieti pe mob; 060215747.
petrea - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 36
Tutti i Tempi: 7,380
