Salta al contenuto principale
Sony Ericsson W810I Logic Board Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Sony Ericsson W810I Logic Board Replacement, Logic Board: passo 1, immagine 1 di 1
    • Make sure the phone is off and press down firmly against the Cingular icon with your thumb
    • Slide the panel down and remove latch
  2. Sony Ericsson W810I Logic Board Replacement: passo 2, immagine 1 di 2 Sony Ericsson W810I Logic Board Replacement: passo 2, immagine 2 di 2
    • Lift and pull battery out
    • Remove the SIM card if you have one
  3. Sony Ericsson W810I Logic Board Replacement: passo 3, immagine 1 di 1
    • Remove the two outer screws using a T-7 head for a screwdriver
  4. Sony Ericsson W810I Logic Board Replacement: passo 4, immagine 1 di 1
    • Remove the two smaller inner screws with the Mini-Phillips screwdriver head
  5. Sony Ericsson W810I Logic Board Replacement: passo 5, immagine 1 di 2 Sony Ericsson W810I Logic Board Replacement: passo 5, immagine 2 di 2
    • Remove the Back (camera side) Faceplate with the blue hand-wedge
  6. Sony Ericsson W810I Logic Board Replacement: passo 6, immagine 1 di 3 Sony Ericsson W810I Logic Board Replacement: passo 6, immagine 2 di 3 Sony Ericsson W810I Logic Board Replacement: passo 6, immagine 3 di 3
    • Flip the phone over and pry off the front (keypad side) faceplate with multiple blue hand-wedges
    • Separate keypad from logic board by turning it upside down and allowing it to fall off
  7. Sony Ericsson W810I Logic Board Replacement: passo 7, immagine 1 di 2 Sony Ericsson W810I Logic Board Replacement: passo 7, immagine 2 di 2
    • Remove the two remaining screws in the top corners of the phone using a T-6 screwdriver head
    • Remove the logic board with multiple blue hand-wedges, be careful not to snap the logic board in half, along with snapping the wiring from the logic board
Conclusione
Altre 2 persone hanno completato questa guida.
Ben Micucci
Membro da: 10/14/11
186 Reputazione
5 Guide realizzate
James Madison, Team 2-2, Allen Fall 2011 Membro di James Madison, Team 2-2, Allen Fall 2011
JMU-ALLEN-F11S2G2
2 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,611
