Salta al contenuto principale
Sony Ericsson W810I Key Pad Replacement
Cosa ti serve
  1. Sony Ericsson W810I Key Pad Replacement, Battery: passo 1, immagine 1 di 1
    • Place your Sony Ericsson W810I screen side down with the battery cover facing up as shown.
  2. Sony Ericsson W810I Key Pad Replacement: passo 2, immagine 1 di 1
    • Remove the battery cover by applying downward pressure on the Singular Symbol and then shifting the pressure towards the bottom edge of the phone.
  3. Sony Ericsson W810I Key Pad Replacement: passo 3, immagine 1 di 2 Sony Ericsson W810I Key Pad Replacement: passo 3, immagine 2 di 2
    • Lift the bottom of the battery away from the phone with your thumb and rotate until the opening in the bottom of the case is oriented downward. The battery should slide out.
  4. Sony Ericsson W810I Key Pad Replacement, Case: passo 4, immagine 1 di 3 Sony Ericsson W810I Key Pad Replacement, Case: passo 4, immagine 2 di 3 Sony Ericsson W810I Key Pad Replacement, Case: passo 4, immagine 3 di 3
    • Remove the two 3.9mm screws with a Phillips size #00 screwdriver.
    • Remove the two 6.35mm screws with a Torx T6 screwdriver.
  5. Sony Ericsson W810I Key Pad Replacement: passo 5, immagine 1 di 3 Sony Ericsson W810I Key Pad Replacement: passo 5, immagine 2 di 3 Sony Ericsson W810I Key Pad Replacement: passo 5, immagine 3 di 3
    • Run a plastic opening tool along the edge of the back casing while prying it apart to remove it.
  6. Sony Ericsson W810I Key Pad Replacement: passo 6, immagine 1 di 3 Sony Ericsson W810I Key Pad Replacement: passo 6, immagine 2 di 3 Sony Ericsson W810I Key Pad Replacement: passo 6, immagine 3 di 3
    • Turn the phone over and open the memory stick compartment.
    • Stick a plastic opening tools into the opening and twist it to gain some leverage. This should begin separating the front casing from the interior plastic support frame.
  7. Sony Ericsson W810I Key Pad Replacement: passo 7, immagine 1 di 3 Sony Ericsson W810I Key Pad Replacement: passo 7, immagine 2 di 3 Sony Ericsson W810I Key Pad Replacement: passo 7, immagine 3 di 3
    • Run the plastic opening tool upwards along that side, removing the housing.
  8. Sony Ericsson W810I Key Pad Replacement, Key Pad: passo 8, immagine 1 di 3 Sony Ericsson W810I Key Pad Replacement, Key Pad: passo 8, immagine 2 di 3 Sony Ericsson W810I Key Pad Replacement, Key Pad: passo 8, immagine 3 di 3
    • Peel the rubber keys away from their backing. Do not slide them off.
    • Set them aside.
  9. Sony Ericsson W810I Key Pad Replacement: passo 9, immagine 1 di 3 Sony Ericsson W810I Key Pad Replacement: passo 9, immagine 2 di 3 Sony Ericsson W810I Key Pad Replacement: passo 9, immagine 3 di 3
    • Insert a plastic opening tool under the left side of the keypad backing and start to lift.
    • Lift slowly, as you can damage the ribbon cable underneath if you pull the keypad backing away too forcefully.
  10. Sony Ericsson W810I Key Pad Replacement: passo 10, immagine 1 di 3 Sony Ericsson W810I Key Pad Replacement: passo 10, immagine 2 di 3 Sony Ericsson W810I Key Pad Replacement: passo 10, immagine 3 di 3
    • Insert the plastic opening tool under the ribbon cable attachment and give a small push upwards to dislodge it.
Conclusione
Altre 2 persone hanno completato questa guida.
Lucy Bowen
Membro da: 09/01/11
449 Reputazione
7 Guide realizzate
Cuesta, Team 1-7, Zipperian Fall 2011 Membro di Cuesta, Team 1-7, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G7
1 Membro
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,403
