Salta al contenuto principale
Sony Ericsson W518a Faceplate Replacement
Cosa ti serve
  1. Sony Ericsson W518a Faceplate Replacement, Faceplate: passo 1, immagine 1 di 1
    • Find the small notch on the side of the phone. The notch is located by the "fast-forward" button and the "lock" switch.
  2. Sony Ericsson W518a Faceplate Replacement: passo 2, immagine 1 di 3 Sony Ericsson W518a Faceplate Replacement: passo 2, immagine 2 di 3 Sony Ericsson W518a Faceplate Replacement: passo 2, immagine 3 di 3
    • Insert your plastic opening tool into the notch.
    • Pry off the faceplate by gently sliding the plastic opening tool around the phone while still keeping the tool under the edge of the phone.
    • When enough of the faceplate has been lifted it can be easily removed.
    • In order to replace the faceplate, simply press and snap the faceplate back onto the front of the phone.
Conclusione
kgkramer
Membro da: 06/27/12
121 Reputazione
2 Guide realizzate
Cal Poly, Team 1-5, Regan SU 2012 Membro di Cal Poly, Team 1-5, Regan SU 2012
CPSU-REGAN-SU12S1G5
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,206
