Salta al contenuto principale
Sony Ericsson W300i Camera Replacement
Cosa ti serve
  1. Sony Ericsson W300i Camera  Replacement, Camera: passo 1, immagine 1 di 2 Sony Ericsson W300i Camera  Replacement, Camera: passo 1, immagine 2 di 2
    • The tools you will need for this step is the prying tool and the T6 Torx screwdriver.
  2. Sony Ericsson W300i Camera  Replacement: passo 2, immagine 1 di 3 Sony Ericsson W300i Camera  Replacement: passo 2, immagine 2 di 3 Sony Ericsson W300i Camera  Replacement: passo 2, immagine 3 di 3
    • Remove the back cover of the phone by pushing downwards with your thumbs.
  3. Sony Ericsson W300i Camera  Replacement: passo 3, immagine 1 di 2 Sony Ericsson W300i Camera  Replacement: passo 3, immagine 2 di 2
    • Now, remove the battery from the phone by gently prying the battery out.
  4. Sony Ericsson W300i Camera  Replacement: passo 4, immagine 1 di 2 Sony Ericsson W300i Camera  Replacement: passo 4, immagine 2 di 2
    • Remove the front plate from the phone by using the prying tool.
  5. Sony Ericsson W300i Camera  Replacement: passo 5, immagine 1 di 2 Sony Ericsson W300i Camera  Replacement: passo 5, immagine 2 di 2
    • You now have access to the fours screws that hold the front of the phone together. Remove the four screws.
  6. Sony Ericsson W300i Camera  Replacement: passo 6, immagine 1 di 2 Sony Ericsson W300i Camera  Replacement: passo 6, immagine 2 di 2
    • Use the prying tool to separate the two parts of the top of the phone
  7. Sony Ericsson W300i Camera  Replacement: passo 7, immagine 1 di 3 Sony Ericsson W300i Camera  Replacement: passo 7, immagine 2 di 3 Sony Ericsson W300i Camera  Replacement: passo 7, immagine 3 di 3
    • Use your fingers to remove the screen and unplug the ribbon cable from the bottom right corner of the back of the screen.
  8. Sony Ericsson W300i Camera  Replacement: passo 8, immagine 1 di 2 Sony Ericsson W300i Camera  Replacement: passo 8, immagine 2 di 2
    • Now you have access to the camera, which is the silver plate at the bottom of the phone. Remove the camera and replace with a new camera.
Conclusione
Laura Inbody
Membro da: 02/19/16
7 Reputazione
1 Guida realizzata
Ohio State, Team 1-2, Garvin Spring 2016 Membro di Ohio State, Team 1-2, Garvin Spring 2016
OSU-GARVIN-S16S1G2
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 356
