Salta al contenuto principale
Sony Ericsson W200i LCD Screen Replacement
Cosa ti serve
  1. Sony Ericsson W200i LCD Screen Replacement, Disassembling Sony Ericsson W200i Battery: passo 1, immagine 1 di 2 Sony Ericsson W200i LCD Screen Replacement, Disassembling Sony Ericsson W200i Battery: passo 1, immagine 2 di 2
    • Slide the battery cover up and off the phone.
  2. Sony Ericsson W200i LCD Screen Replacement: passo 2, immagine 1 di 2 Sony Ericsson W200i LCD Screen Replacement: passo 2, immagine 2 di 2
    • Pop the battery out of its slot by lifting it up.
  3. Sony Ericsson W200i LCD Screen Replacement, Front Case: passo 3, immagine 1 di 3 Sony Ericsson W200i LCD Screen Replacement, Front Case: passo 3, immagine 2 di 3 Sony Ericsson W200i LCD Screen Replacement, Front Case: passo 3, immagine 3 di 3
    • Insert the plastic opening tool in between the front case and the back case.
    • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
  4. Sony Ericsson W200i LCD Screen Replacement, Core: passo 4, immagine 1 di 2 Sony Ericsson W200i LCD Screen Replacement, Core: passo 4, immagine 2 di 2
    • Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver.
    • Note that the top 2 screws are silver and the bottom 2 screws are black.
  5. Sony Ericsson W200i LCD Screen Replacement: passo 5, immagine 1 di 3 Sony Ericsson W200i LCD Screen Replacement: passo 5, immagine 2 di 3 Sony Ericsson W200i LCD Screen Replacement: passo 5, immagine 3 di 3
    • There is a black tab in the top left corner holding the core in place.
    • Remove the core by pulling straight up to prevent breaking the tab.
  6. Sony Ericsson W200i LCD Screen Replacement, LCD Screen: passo 6, immagine 1 di 3 Sony Ericsson W200i LCD Screen Replacement, LCD Screen: passo 6, immagine 2 di 3 Sony Ericsson W200i LCD Screen Replacement, LCD Screen: passo 6, immagine 3 di 3
    • Undo the metal clip on each side of the core using the plastic opening tool.
    • Do not bend clips past 2mm or they could break.
  7. Sony Ericsson W200i LCD Screen Replacement: passo 7, immagine 1 di 3 Sony Ericsson W200i LCD Screen Replacement: passo 7, immagine 2 di 3 Sony Ericsson W200i LCD Screen Replacement: passo 7, immagine 3 di 3
    • Gently pull the white keyboard and charging port away from the motherboard and off the phone.
  8. Sony Ericsson W200i LCD Screen Replacement: passo 8, immagine 1 di 3 Sony Ericsson W200i LCD Screen Replacement: passo 8, immagine 2 di 3 Sony Ericsson W200i LCD Screen Replacement: passo 8, immagine 3 di 3
    • Undo the grey clip that holds the LCD ribbon in place by loosening one side of the clip with the plastic opening tool, then gently separate the other side of the clip from the holder.
    • The copper end of the ribbon should slide out of the housing as you pull the LCD up and away from the motherboard.
    • Using too much force may bend the copper ribbon.
Conclusione
Altre 2 persone hanno completato questa guida.
Austin Cade
Membro da: 01/11/11
198 Reputazione
1 Guida realizzata
Cal Poly, Team 14-10, Forte Winter 2011 Membro di Cal Poly, Team 14-10, Forte Winter 2011
CPSU-FORTE-W11S14G10
5 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 8,147
