Salta al contenuto principale
Sony Ericsson W200i Keypad Replacement
Cosa ti serve
  1. Sony Ericsson W200i Keypad Replacement, Disassembling Sony Ericsson W200i Battery: passo 1, immagine 1 di 2 Sony Ericsson W200i Keypad Replacement, Disassembling Sony Ericsson W200i Battery: passo 1, immagine 2 di 2
    • Slide the battery cover up and off the phone.
  2. Sony Ericsson W200i Keypad Replacement: passo 2, immagine 1 di 2 Sony Ericsson W200i Keypad Replacement: passo 2, immagine 2 di 2
    • Pop the battery out of its slot by lifting it up.
  3. Sony Ericsson W200i Keypad Replacement, Front Case: passo 3, immagine 1 di 3 Sony Ericsson W200i Keypad Replacement, Front Case: passo 3, immagine 2 di 3 Sony Ericsson W200i Keypad Replacement, Front Case: passo 3, immagine 3 di 3
    • Insert the plastic opening tool in between the front case and the back case.
    • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
  4. Sony Ericsson W200i Keypad Replacement, Keypad: passo 4, immagine 1 di 2 Sony Ericsson W200i Keypad Replacement, Keypad: passo 4, immagine 2 di 2
    • Using the plastic opening tool, press down anywhere on the keypad to separate it from the front case.
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team 14-10, Forte Winter 2011 Membro di Cal Poly, Team 14-10, Forte Winter 2011
CPSU-FORTE-W11S14G10
5 Membri
16 Guide realizzate
Un commento
Can you guys tell me where i do get parts for these legacy phones?My jostick died on this phone.Not working at all i only can use the keypad.
Janos Lazar - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 5,508
