Introduzione
This guide will assist you in removing the vibration motor from your Sony Ericsson T68i.
Parti
Nessuna parte richiesta.
  1. Remove the battery from the back. Remove the battery from the back.
    • Remove the battery from the back.
  2. Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips.
    • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
    • Do not bend it too far down, or else you risk breaking the two bottom clips.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Unscrew all four Torx T6 screws. Keep in a safe place. Keep in a safe place.
    • Unscrew all four Torx T6 screws.
    • Keep in a safe place.
  5. After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart.
    • After removing the screws, the two halves will separate. If not, then pry them gently apart.
  6. Remove the vibration motor visible in the front housing. Remove the vibration motor visible in the front housing.
    • Remove the vibration motor visible in the front housing.
Conclusione
Tim Dascomb
Membro da: 13/04/2010
123 Reputazione
7 Guide realizzate
Cal Poly, Team 26-34, Regan Spring 2010 Membro di Cal Poly, Team 26-34, Regan Spring 2010
CPSU-REGAN-S10S26G34
4 Membri
13 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,365
