Salta al contenuto principale
Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement
Cosa ti serve
  1. Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement, Sony Ericsson QuickShare T630 Phone Enclosure: passo 1, immagine 1 di 1
    • Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
  2. Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement: passo 2, immagine 1 di 2 Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement: passo 2, immagine 2 di 2
    • Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
  3. Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement: passo 3, immagine 1 di 1
    • Slide the battery upward to remove.
  4. Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement: passo 4, immagine 1 di 2 Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement: passo 4, immagine 2 di 2
    • Remove the rubber plug located near the camera by gently prying upward with your fingers.
    • Gently lift the camera shield after removal of the rubber plug.
  5. Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement: passo 5, immagine 1 di 2 Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement: passo 5, immagine 2 di 2
    • Pry the remaining panel to loosen its contact to the phone using a spudger.
    • Slide the panel upward to remove it completely.
    • These steps will require a slight appliance of force.
  6. Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement: passo 6, immagine 1 di 1
    • Slide the aerial upward to remove it.
  7. Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement: passo 7, immagine 1 di 2 Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement: passo 7, immagine 2 di 2
    • Remove the four screws located at each corner of the device.
  8. Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement: passo 8, immagine 1 di 2 Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement: passo 8, immagine 2 di 2
    • Gently lift and remove the front panel of the phone after removing the screws.
  9. Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement: passo 9, immagine 1 di 3 Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement: passo 9, immagine 2 di 3 Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement: passo 9, immagine 3 di 3
    • This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals.
    • Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
    • Gently pull the ribbon from the circuit.
    • Remove the now disconnected screen.
  10. Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement: passo 10, immagine 1 di 3 Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement: passo 10, immagine 2 di 3 Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement: passo 10, immagine 3 di 3
    • Remove the keyboard by slowly pulling it away from the circuit board.
    • There are no direct connections between the keyboard and phone.
    • These are all of the parts covered in this disassembly that make up the Sony Ericsson QuickShare T630.
  11. Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement, Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement: passo 11, immagine 1 di 2 Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement, Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement: passo 11, immagine 2 di 2
    • After wetting the cotton swab with the rubbing alcohol, rub the keypad with the swab until the buttons are clean.
    • Dry out the keypad by placing it on a flat surface before reassembling the device.
  12. Sony Ericsson QuickShare T630 Keypad Maintenance and Replacement: passo 12, immagine 1 di 1
Conclusione
Kelsey
Membro da: 10/28/13
107 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 927
