Salta al contenuto principale
Sony Ericsson K750i Joystick Replacement
Cosa ti serve
  1. Sony Ericsson K750i Joystick Replacement, Battery Cover: passo 1, immagine 1 di 1
    • Remove the battery cover.
    • Press down firmly with your thumb and slide the cover back.
  2. Sony Ericsson K750i Joystick Replacement, Back Casing: passo 2, immagine 1 di 1
    • Remove two Phillips #0 screws from the battery chamber.
    • Remove two Torx T6 screws from the battery chamber.
  3. Sony Ericsson K750i Joystick Replacement: passo 3, immagine 1 di 1
    • Gently pry off the back casing.
    • Work an opening tool around the entire seam before attempting to pull off the casing. This action will reduce the chance of cracking the casing.
  4. Sony Ericsson K750i Joystick Replacement: passo 4, immagine 1 di 1
    • Remove the casing to expose the camera's components.
  5. Sony Ericsson K750i Joystick Replacement, Keypad: passo 5, immagine 1 di 1
    • Gently pry open the front casing by working an opening tool along the entire seam.
  6. Sony Ericsson K750i Joystick Replacement: passo 6, immagine 1 di 1
    • Remove the front casing by gently lifting it from the phone.
    • Be careful not to pull off any other delicate pieces.
  7. Sony Ericsson K750i Joystick Replacement: passo 7, immagine 1 di 2 Sony Ericsson K750i Joystick Replacement: passo 7, immagine 2 di 2
    • Remove the keypad.
    • The LCD screen is very fragile. Be careful not to catch the keypad on it while removing.
  8. Sony Ericsson K750i Joystick Replacement, Joystick: passo 8, immagine 1 di 1
    • Remove the front cover and casing to expose the joystick.
  9. Sony Ericsson K750i Joystick Replacement: passo 9, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to get a grip on the joystick.
  10. Sony Ericsson K750i Joystick Replacement: passo 10, immagine 1 di 1
    • Once you have a firm grip, carefully remove the joystick.
    • Caution: The green film surrounding the joystick is fragile. Take care not to puncture or rip it.
  11. Sony Ericsson K750i Joystick Replacement: passo 11, immagine 1 di 1
    • Using tweezers, insert the new joystick in place of the previous joystick.
Conclusione
Altre 3 persone hanno completato questa guida.
Abby Evers
Membro da: 10/04/11
202 Reputazione
6 Guide realizzate
UW Stout, Team 1-6, Zhou Fall 2011 Membro di UW Stout, Team 1-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G6
4 Membri
12 Guide realizzate
Un commento
That is the joystick head and it can be removed without taking anything apart. The problem is in joystick underneath it, which is soldered and need to be replaced. I know this phone is 15 years old, I just found mine and it brought back some memories :)
Lazar Trnavac - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 26
Tutti i Tempi: 6,959
