Salta al contenuto principale
Sony Ericsson K750i Back Casing Replacement
Cosa ti serve
  1. Sony Ericsson K750i Back Casing Replacement, Battery Cover: passo 1, immagine 1 di 1
    • Remove the battery cover.
    • Press down firmly with your thumb and slide the cover back.
  2. Sony Ericsson K750i Back Casing Replacement, Back Casing: passo 2, immagine 1 di 1
    • Remove two Phillips #0 screws from the battery chamber.
    • Remove two Torx T6 screws from the battery chamber.
  3. Sony Ericsson K750i Back Casing Replacement: passo 3, immagine 1 di 1
    • Gently pry off the back casing.
    • Work an opening tool around the entire seam before attempting to pull off the casing. This action will reduce the chance of cracking the casing.
  4. Sony Ericsson K750i Back Casing Replacement: passo 4, immagine 1 di 1
    • Remove the casing to expose the camera's components.
Conclusione
Abby Evers
Membro da: 10/04/11
202 Reputazione
6 Guide realizzate
UW Stout, Team 1-6, Zhou Fall 2011 Membro di UW Stout, Team 1-6, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G6
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 3,536
