Salta al contenuto principale
Sony Dream Machine ICF-C717PJ Screen Replacement
Cosa ti serve
  1. Sony Dream Machine ICF-C717PJ Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Using a Phillips #0 screwdriver unscrew the three screws that connect the back panel to the device.
  2. Sony Dream Machine ICF-C717PJ Screen Replacement: passo 2, immagine 1 di 1
    • Using a thin flat tool, pry off the panel on the back of the device.
  3. Sony Dream Machine ICF-C717PJ Screen Replacement: passo 3, immagine 1 di 2 Sony Dream Machine ICF-C717PJ Screen Replacement: passo 3, immagine 2 di 2
    • Unscrew the two screws connecting the motor board to the device.
    • Gently remove the motherboard from the device to gain access to the screen.
  4. Sony Dream Machine ICF-C717PJ Screen Replacement: passo 4, immagine 1 di 2 Sony Dream Machine ICF-C717PJ Screen Replacement: passo 4, immagine 2 di 2
    • Flip the device around so that the display is facing you. Gently push the display towards the inside of the device.
    • Disconnect the display cable from the motherboard and reconnect the display cable for the new display.
    • After connecting the new display push it firmly in place so that the display panel is properly aligned with the cutout for the display. When correctly locked in place the display panel should not move around.
Conclusione
Gurleen Powar
Membro da: 08/11/18
376 Reputazione
3 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,392
